Old 11-05-2015, 07:43 PM   #15
tzbang
Drives: 2013 GT86
what is CARB legal? (haven't heard that term before) Are you talking specifically about a OFT tune or Ecutek or something else?
tzbang is offline   Reply With Quote
Old 11-05-2015, 07:45 PM   #16
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
It's USA speak, specifically California, for meeting emissions compliance. I think you'll be okay.
LOLS2K is offline   Reply With Quote
The Following User Says Thank You to LOLS2K For This Useful Post:
strat61caster (11-06-2015)
Old 11-05-2015, 07:57 PM   #17
tzbang
Drives: 2013 GT86
Interesting, I would have thought the emissions would be more related to the ECU tuning rather than the kit?
So people running FI on the 86 on your 91octane, do they use OFT or Ecutek tunes? Seems like most of the reflashing tunes specify a premium 93 or E85 fuel..
Old 11-05-2015, 08:31 PM   #18
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
CARB (California Air Resources Board) has a set of guidelines that limit the tailpipe emissions of vehicles in that state. That's primarily NOx and hydrocarbon emissions.
You can do tricky things with the three-way catalyst... but generally speaking, this means that the ECU tune is maintaining a pretty tight range of cylinder temperature/pressures.
Here are some popular graphs that illustrate emissions and how things change with temp/pressure/O2.
Too hot (or lean), and you get NOx. Too much pressure (or rich), and you get HC.
CARB tunes keep the mixture near stoichiometry (chemical balance) and cylinder temps/pressures low enough. You may not get the best power or fuel economy from a CARB tune... but it's likely to be very reliable and safe.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following 2 Users Say Thank You to Shankenstein For This Useful Post:
CSG Mike (11-06-2015), strat61caster (11-06-2015)
Old 11-05-2015, 08:34 PM   #19
mkivsoopra
That, and catalytic converters. But that conclusion requires logical thinking, something California legislators lack.
mkivsoopra is offline   Reply With Quote
Old 11-05-2015, 10:27 PM   #20
steve99
Drives: FT86
With so many supercharger kits available I wondered what the opinion was regarding installation differences / simplicity. With the exception of the Phantom for obvious reasons.
I'm not a noddy and have worked on lots of cars before. But my car is a DD and it's not used for track work so this isn't about which is best. I just want some relatively pain free FI to make the car more exciting and it would be good to factor this in with the kit decision.
Cheers
(I realise most people probably choose a kit and have stuck with it, so probably not many people know what it's like installing other kits)
Ease of installation probably the easiest would be sprintex non-intercooled kit, but low boost and probably not to good in warmer climates. They also have intercooled option
http://www.sprintex.com.au/frsbrz/
Old 11-05-2015, 10:43 PM   #21
FT86RGV
He is correct. Never installed a forced induction kit in my life. Brother and I did it in under 5 hrs in my garage. Won't even have to remove bumper for non-intercooled kit. As simple as unbolting throttle body, remove stock intake manifold, drop in new manifold with supercharger, run all the lines, and bolt back throttle body.
That being said. I eventually went intercooled and flex fuel and power is now feeling dull for my taste. If I had another chance probably would go edelbrock for the chance at more power or possibly even turbo.
FT86RGV is offline   Reply With Quote
Old 11-05-2015, 10:45 PM   #22
djdnz
1337
Drives: 2013 BRZ WRB S/C
Since you're next door to Australia don't forget about Harrop, shouldn't be that much different than edelbrock.
djdnz is offline   Reply With Quote
Old 11-06-2015, 03:52 PM   #23
stevo585
Drives: White 2014 BRZ
The phantom ESC is by far the easiest but its not mass produced so doesn't really count...
stevo585 is offline   Reply With Quote
The Following User Says Thank You to stevo585 For This Useful Post:
Dream20b (11-09-2015)
Old 11-06-2015, 10:01 PM   #24
CSG Mike
CSG Mike's Avatar
Well... you could make the same sustainable power as a Sprintex kit with an Ace header and solid tune, with way less work
Old 11-07-2015, 02:13 AM   #25
steve99
Drives: FT86
More torque though, no it would npt do it either though
Old 11-07-2015, 08:19 AM   #26
xwd
What does sustainable mean? Because no, you aren't.
Old 11-08-2015, 06:59 AM   #27
stevo585
The sprintex kit really needs to run e85 full time especially if non inter cooled to fight off heat soak.
Boofneenee (11-09-2015)
Old 11-08-2015, 09:26 PM   #28
tzbang
Drives: 2013 GT86
Thanks for the replies, are their any opinions about which kit would be best suited to 93octane fuel? (our 98Ron is the best I can get - no E85 at the pumps)
I assume this will mean a low boost application.
LCA install WallsAndFoundations Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 12-16-2014 05:47 AM
Easiest oil change tzhu07 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 51 04-18-2014 10:27 AM
easiest color to keep looking clean? fatoni Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 25 10-10-2013 07:21 PM
Easiest way to get to the over-pipe? Doing an install... seven Engine, Exhaust, Transmission 7 02-03-2013 07:38 AM
Colors easiest to keep clean yet looks good fitcious Scion FR-S / Toyota 86 GT86 General Forum 31 01-16-2013 02:22 PM
