Old 12-03-2014, 03:27 PM   #1
WallsAndFoundations
WallsAndFoundations's Avatar
Drives:
LCA install
Is it a trade secret to install these? Why no tutorials online or anywhere? This car noob can't do shit right now.
WallsAndFoundations is offline   Reply With Quote
Old 12-03-2014, 03:39 PM   #2
Koa
not to be a ****, but the install process is very straightforward and if you're capable of doing it yourself, it will be easy to see what needs be done by getting under the car and looking at the control arm.
1. Jack the rear of the vehicle up after breaking the torque of your rear wheel lugs
2. Take off the rear wheels
3. Take off the bolts connecting the LCA to the strut, hub, sway, and chassis
4. replace and bolt to spec
Also, view the FSM and it will tell you everything man
http://www.ft86club.com/forums/showthread.php?t=8448
The Following User Says Thank You to Koa For This Useful Post:
Wes (12-06-2014)
Old 12-03-2014, 03:39 PM   #3
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
http://www.moddit.com/Guide/How+to+i...+Subaru+BRZ/31
2URGSE
JPxM0Dz is offline   Reply With Quote
The Following User Says Thank You to JPxM0Dz For This Useful Post:
Guillaume (12-04-2014)
Old 12-03-2014, 03:40 PM   #4
BlUURZ
Drives: BRZ 6MT
a few bolts, if you've done coilovers it's simple. Depending on the lcas you bought you might need toe arms to get the toe straight. I just jacked up the rear and got it done.
BlUURZ is offline   Reply With Quote
Old 12-03-2014, 04:03 PM   #5
WallsAndFoundations
Drives:
Stance adjustable lcas
Old 12-03-2014, 04:05 PM   #6
WallsAndFoundations
Drives:
A normal LCA seems pretty easy, but I got a set of adjustable LCAs from stance and I'm not sure if it'll be as easy. I'll give that link as read. I also need to figure out how much to torque it
Old 12-03-2014, 04:06 PM   #7
WallsAndFoundations
Drives:
Originally Posted by JPxM0Dz View Post
Where are these links in google? I must have tried 80 different search terms and nothing was brought up except places to BUY LCAs.
Old 12-03-2014, 04:09 PM   #8
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
I just googled LCA INSTALL BRZ using google.ca. It's the first link that pops up
2URGSE
wparsons (12-03-2014)
Old 12-03-2014, 04:18 PM   #9
anewprelusion
Just make sure you get alignment done as soon as possible after install, and also helps if it's nearby.
I had my Buddy Club LCA's installed at Buddy Club's facility (they wanted to test some things out). They eyeballed the Toe, and used a measuring tool for the Camber.
After I drove off, the car was nearly uncontrollable at over 30mph, and I could smell my tires wearing off. I had to nurse the car over to an alignment shop.
Results showed the Toe was grossly off. = /
anewprelusion is offline   Reply With Quote
Old 12-03-2014, 04:42 PM   #10
Koa
Stance LCA's use the same exact mounting points.
The only differences for Stance is their geometry, part materials and end joints.
Old 12-03-2014, 05:10 PM   #11
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
I thought it was best to tighten the control arm bolts(not endlink, coilover bolts) with the suspension loaded? Didn't see that step on the moddit link.
yomny is offline   Reply With Quote
The Following User Says Thank You to yomny For This Useful Post:
Imrac (12-03-2014)
Old 12-03-2014, 08:36 PM   #12
Imrac
Drives: 13 SWP BRZ Prem
Word.
I installed my LCA myself, didn't adjust to recommended settings as I didn't have wrenches big enough so it was at it's shortest length.
My alignment shop luckily was less then a mile down the road, but for that mile it was scarry. Toe was so off you could see it, my traction control would pop on going around a 90 degree bend at 10 MPH. The tires would screech when making small turns and the back end would shimmy back and forth going straight.
When I had the alignment done my toe was at 4 Degrees of toe out! Made for a very exciting drive.
I believe this is correct. That is what I did, Just shoved the jack under the hub and compressed each side.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 12-03-2014, 08:54 PM   #13
Jack up car safely.
Remove 4 bolts, swap LCA, reinstall 4 bolts. Repeat on other side. Torque all bolts to spec.
No offense, but put it this way. This is one of those installs where if you cannot figure it out by looking, you REALLY should pay for someone to do it for you. This is not an entry level DIY like an oil change (which will have DIYs, because it is entry level).
Old 12-03-2014, 11:37 PM   #14
WallsAndFoundations
Drives:
Jack up car safely.
Thank you. The install is very straight forward, I was talking more so what specs should I tighten it to? I couldn't find a guide that explained that. Should I just do it til it's tight or...?
Install Day anyone? darkonion Northern California 23 06-20-2014 05:15 PM
Pro kit install B-R-Z Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-06-2014 11:47 AM
Which mod to install first .... ?? humfrz Scion FR-S / Toyota 86 GT86 General Forum 9 11-09-2013 09:07 PM
MTX install Deadspool Electronics | Audio | NAV | Infotainment 1 06-27-2013 07:21 AM
Need help with HID install ortizwyld Cosmetic Modification (Interior/Exterior/Lighting) 4 02-21-2013 11:12 PM
