Old 09-19-2015, 01:28 AM   #15
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Originally Posted by Roneezy View Post
I've been browsing through the forums and found that people recommend -3 camber in the front and -2 in the rear with 0 toes for front and rear.
I don't autox or go to the track. when i went to west end alignment, and told chris that my car was a daily driver, but i tend to take corners on the aggressive side and occasionally go on canyon runs, he recommended these settings:
Front -1.3° camber, 1/16" toe in
Rear -1.75° camber, 3/32" toe in
I've been driving on these settings for more than a year and am happy with them. i have camber bolts in the front and LCAs in the rear.
shiumai is offline   Reply With Quote
The Following 2 Users Say Thank You to shiumai For This Useful Post:
ARTBRZ (09-19-2015), Roneezy (09-19-2015)
Old 09-19-2015, 04:06 AM   #16
ZionsWrath
Thanks
ZionsWrath's Avatar
I'll finally get my alignment on Monday since I just received my camber bolts and my control arms.
Does this sound good? I'll be telling them to align to these specs on Monday if these are good, or if anyone has some good recommendations I'd appreciate the help thank you.
Don't think you will get -3 with bolts. Likely 1.5 maybe 2.
The Following User Says Thank You to ZionsWrath For This Useful Post:
Old 09-19-2015, 09:41 AM   #17
bfrank1972
Drives: 2013 FR-S Argento
Yeah you will need to have camber plates, slot your struts, or use a 2nd set of camber bolts to get much more than -1.5 on the front
The Following User Says Thank You to bfrank1972 For This Useful Post:
Old 09-19-2015, 09:43 AM   #18
wparsons
wparsons's Avatar
That's extremely conservative/stable on all settings. With that much toe it, the car really won't want to turn and more camber in the rear will increase understeer as well, plus make tire wear worse.
I would suggest:
-1.5 front camber
0 front toe
-1 rear camber
1/16" total rear toe in
flickr
Old 09-19-2015, 10:05 AM   #19
ARTBRZ
Aloha!
ARTBRZ's Avatar
Did you do what was described in an earlier post? (Camber bolts and lower control arms) I'm also planning to drop in eibach.
ARTBRZ is offline   Reply With Quote
Old 09-19-2015, 01:30 PM   #20
shiumai
shiumai's Avatar
yup.
Old 09-19-2015, 01:36 PM   #21
shiumai
shiumai's Avatar
I would suggest:
-1.5 front camber
0 front toe
-1 rear camber
given that it's a 90% daily driver, i went with more conservative/stable vs. twitchy. i discussed with west end what i wanted, and went with their recommended settings. i'm getting coilovers installed by them on monday, so i'll revisit the settings.
Old 09-19-2015, 06:13 PM   #22
ARTBRZ
Aloha!
ARTBRZ's Avatar
What lca do u guys recommend?
Old 09-19-2015, 07:05 PM   #23
Roneezy
Roneezy's Avatar
Drives: Scion FRS Halo White 2015
I heard SPC were good which is the one I just received in the mail.
@Mr.ac It'll mostly be a daily driver, with some canyon runs and some aggressive turning here and there but that's pretty much it. No autox or track ever.
@wparsons Thank you for suggesting these settings, I'll most likely go with these when I get it aligned on Monday.
Thank you guys for the helpful suggestions, I really appreciate it.
Roneezy is offline   Reply With Quote
The Following User Says Thank You to Roneezy For This Useful Post:
ARTBRZ (09-19-2015)
Old 09-21-2015, 11:16 PM   #24
shiumai
shiumai's Avatar
I would suggest:
-1.5 front camber
0 front toe
-1 rear camber
Got my coilovers installed today and we changed the front camber to -1.6° and 1/32" toe in. Left the rear the same.
Again, this is based on my driving habits/needs. Man, what a difference the coilovers make vs. the Swift lowering springs/stock shocks.
The Following User Says Thank You to shiumai For This Useful Post:
Roneezy (09-22-2015)
Old 09-22-2015, 02:45 AM   #25
Roneezy
Roneezy's Avatar
I went with the
-1.5 Front
0 Front toes
-1 Rear
1/16 rear toe in
I like this a lot, thank you everyone with the input. I took care of it today and it feels great.
wparsons (09-22-2015)
Lowering and Alignment Question DieselDog Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-24-2015 12:40 PM
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 06:41 PM
For anyone not getting an alignment after lowering... wparsons Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-16-2014 12:13 AM
Alignment After Lowering mjsivee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-11-2013 12:12 PM
Alignment needed after lowering car? Lowellrenzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-16-2012 03:57 PM
