Drives: _____
5th gear downshift grind- Toyota says it's normal...
My 2013 FR-S has started to get notchy and grind when I downshift from 6th to 5th at above 60mph. I also get an occasional grind into 6th. This started at about 10k miles and I'm currently just under 13k miles. As far as I can tell this is a well documented issue. The dealer at first could not reproduce the problem. I went for a test drive with a tech and they agreed, not normal. The next day two other techs say it's normal. Service manager contacts Toyota and they say this is normal. They are telling me now to bring it back when it gets worse.
Anyone else gotten this run around with this problem? How did you get action? |
#2 |
Drives: '14 WRB BRZ 6MT Limited
Keep bringing it back to them or to a new dealer. Bug them enough and they'll do something about it (read: new transmission).
| 4th gear grind | aaguirre123 | Engine, Exhaust, Transmission | 8 | 08-03-2015 05:58 PM |
| 5th and 6th gear grind... | Basket Case | Engine, Exhaust, Transmission | 7 | 02-11-2015 09:53 PM |
| Grind Into 5th Gear | Since885 | Engine, Exhaust, Transmission | 8 | 01-18-2015 06:47 PM |
| 2nd gear grind (yup another one) | SmartedPanda | Issues | Warranty | Recalls / TSB | 17 | 09-10-2014 05:02 PM |
| 4th gear grind | Moetivegt86 | Issues | Warranty | Recalls / TSB | 10 | 03-07-2014 12:50 PM |
