Old 04-08-2015, 12:44 AM   #1
WhiteChocolate
WhiteChocolate's Avatar
Drives: White like Chocolate
Traction and CEL Light
Today I had my traction control light come on once again. This is the 3rd time. I took it to the dealer both times. First time they changed out the ECU and it fixed it for a little then the lights came back. Then next the problem was the camshafts or cam sprocket (can't remember off the top of my head). But now its back. Anyone aware with what the problem can be. I have a manual Transmission
WhiteChocolate is offline   Reply With Quote
Old 04-08-2015, 05:06 AM   #2
steve99
Drives: FT86
Without knowing the cel code it difficult , but usually you would suspect a wheel speed sensor.
Old 04-08-2015, 08:55 AM   #3
WhiteChocolate
When I went to the dealer they said something about the cams last time I went. This is just frustrating cause it's gonna be my 3rd time going in
Old 04-08-2015, 01:40 PM   #4
victorb
Drives: Black 86
Had lots of 86/brzs here in the Philippines encountering that. Toyota dealers have been replacing the brake switch near the pedal.....fixed most of them. Good luck sir
victorb is offline   Reply With Quote
Old 04-08-2015, 07:15 PM   #5
WhiteChocolate
Ill run it by the service guys at the dealer
Old 04-08-2015, 07:44 PM   #6
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Has anyone disconnected the main engine harness in the past? That can throw out random codes if it's not seated properly when reconnected.
JimmyMac is offline   Reply With Quote
Old 04-08-2015, 07:49 PM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I always thought AVCS failure was a different light, some weird CEL code.
Old 04-08-2015, 07:53 PM   #8
WhiteChocolate
I have an appointment monday so ill keep everyone posted
Old 04-08-2015, 07:55 PM   #9
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Whats your MY?
Old 04-08-2015, 08:16 PM   #10
WhiteChocolate
Whats your MY?
Whats MY? lolol
Old 04-08-2015, 08:31 PM   #11
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Whats MY? lolol
Model year. Lol it took me a long time and some critical reading to figure it out haha
Old 04-08-2015, 10:20 PM   #12
steve99
Drives: FT86
That my take as well
Cam actuator VVT issues usually CEL P0016,P0017,P0018,P0019. Usually triggers check engine light and car runs rough sometimes especially idle.
Traction light usually indicates prblem with wheel speed sensors , brake switch or something weird with vehicle stability ABS systems ect.
cdrazic93 (04-08-2015)
Old 04-09-2015, 01:19 AM   #13
WhiteChocolate
2013 frs
Old 04-09-2015, 01:19 AM   #14
WhiteChocolate
Thumbs down
Hopefully its something along those lines. Just sucks having the nearest dealer 45 minutes away
traction light, engine light = cam sprocket , ecu nivek111070 Issues | Warranty | Recalls / TSB 27 03-13-2016 10:28 AM
Abs and Traction Light nabil_frs Issues | Warranty | Recalls / TSB 14 07-09-2015 10:39 AM
ABS + Traction Light After Fog Install Wyattkb Issues | Warranty | Recalls / TSB 1 03-22-2015 06:47 PM
CEL and Traction Light came on today myjobis2pimp NY / NJ / CT / PA 9 10-05-2014 02:45 AM
CEL ABS and Traction Light DieselxIndustry Issues | Warranty | Recalls / TSB 3 01-31-2013 02:04 PM
