#15 |
Drives: UK GT86
Did anyone create a good accurate-ish calibration for this? I've had a go based on my dyno wideband results from the weekend but I know that tailpipe generated results won't be as accurate, so I'd like to see what other have done.
.: Stealth 86 :.
#16 |
Drives: Toyota 86
Resurrecting this thread.
Looking down the Denso doc that arghx7 shared, I see more extended curves later on. Also looking at stock and Shiv's 1.59 O2 scales, looks like there is a lot more data that can be plugged into the bottom end of the scale, with the 3 cells over 0.43mA not being needed. Has anyone benchtested the particular sensor that we have and give us scaling values for the rich end of the scale in better resolution? Off the paper curves (which don't match stock ROM values): AFR mA 10 -1.8 11 -1.25 12 -0.8 13 -0.45 |
#17 |
Drives: UK GT86
EcuTek have and supply it in their documentation....
.: Stealth 86 :.
#19 | |
Drives: Toyota 86
I had a look at the Bosch 4.9 and Denso curves - they are quite similar in mA vs lambda measurements. Our stock ROM reads quite close to the Bosch curve x 0.61. Made an extended table for the front O2 sensor scaling that is shown below (working down to a 10.5 limit, next testing a 10.0 limit). The results of that curve vs a PLX SM-AFR (installed last week) with Bosch 4.9 wideband (units in lambda with range from 0.68-1.38) attached. I think that with the extended scaling, the Denso sensor actually performs quite well. The ECU sensor has a smoothed output and I think that is responsible for the higher variability on the lean quadrant of the chart when switching between fueling and deceleration cut. |
#20 |
Drives: 2013 Scion FR-S Asphault
| Map Sensor Hookup? | ft86-UAE | Forced Induction | 22 | 01-08-2015 04:56 PM |
| Is P0108 (MAP sensor) common ? | regal | Issues | Warranty | Recalls / TSB | 0 | 10-06-2012 01:21 PM |
| Bad MAF Sensor | paulieblaze | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 08-23-2012 11:34 PM |
| How to fool airbag sensor? | track_warrior | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 07-13-2012 12:46 AM |
| Stock O2 Sensor | d1ck | Engine, Exhaust, Transmission | 1 | 07-11-2012 08:16 AM |
