Old 01-08-2015, 11:40 PM   #1
Oakhenshield
Oakhenshield's Avatar
Drives: ahh its blue?
Headlights or HID Problem?
So i got a winjet headlights and installed opt7 H7 hid now heres my problem..
theres a loss of light from the right headlight and when im seated i cant see the light because i was expecting it to be like this (last photo)
road is in level and wet coz of the melted snow
any fix for this?
my last hid which is opt7 h11 wasnt like this on stock headlights
Right side
Left side
In front
Me inside, positioned my phone near the rear mirror sorry if blurry
Bruuuum Bruuuum!
Oakhenshield is offline   Reply With Quote
Old 01-08-2015, 11:49 PM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I feel like there's an aiming issue or a squirrel finder issue
Old 01-09-2015, 12:07 AM   #3
Oakhenshield
Anyway to fix that?
Bruuuum Bruuuum!
Old 01-09-2015, 12:14 AM   #4
Bergen23
Drives: '15 Halo FR-S
Adjust the headlights. I'm sure that's a thing on the Winjet headlights. It'll probably look like a dial. Although I'm unsure what the winjet specifically looks like.
This was the first result of googling "winjet headlight adjustment"
Winjet FRS/BRZ Headlight Cutoff Adjustment: [ame]http://youtu.be/hye_OnwEyTs[/ame]
Bergen23 is offline   Reply With Quote
The Following User Says Thank You to Bergen23 For This Useful Post:
Oakhenshield (01-09-2015)
Old 01-09-2015, 12:26 AM   #5
lukey86
Built Not Bought
lukey86's Avatar
Drives: 2012 Toyota 86 ZN6
My winjets were the same, adjusted them like in the video above but theyre still crappy quality, and thats with the best bulbs I could get.
lukey86 is offline   Reply With Quote
Old 01-09-2015, 12:36 AM   #6
iLaw
iLaw's Avatar
Drives: 2015 BRZ, Aozora Edition
Have you checked to make sure the bulb is seated properly in the housing? I know it sounds like a noob thing, but it could be the culprit.
iLaw
2020 Subaru Crosstrek Sport
2015 Subaru BRZ Aozora Edition (Sold)
iLaw is offline   Reply With Quote
Old 01-09-2015, 12:39 AM   #7
lukey86
Built Not Bought
lukey86's Avatar
Actually come to think of it, that's actually a good point. In my case it wasn't the bulb but the projector was loose inside it's housing. Had to use a screwdriver to pop it back in
Old 01-09-2015, 12:55 AM   #8
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
They either need adjusting or the bulb isn't seated properly.
Based off the 4th pic, the right side looks seated properly because you can see the cutoff but the left side looks like a combination of both problems.
Old 01-09-2015, 01:47 AM   #9
Oakhenshield
guys.. i checked everything and then i remembered a video on youtube that said the base of the bulb must be vertical so that its seated properly so i did it and it fix my probs and i adjusted the headlights..
Now the stupid thing is all of a sudden the right hid turned purple, wtf? plus i lost my 10mm socket in the dark
Bruuuum Bruuuum!
Old 01-09-2015, 01:52 AM   #10
Andrew025
Andrew025's Avatar
So now you'll want to see if the problem is the ballast or the bulb.
You'll want to check the purple bulb on the left ballast to see if the bulb lights up normal. If it does, check the left bulb on the right ballast as well to double check the ballast is bad.
If it's still purple after connecting to the left ballast, then it's probably a bulb issue.
The Following User Says Thank You to Andrew025 For This Useful Post:
Old 01-09-2015, 02:01 AM   #11
Oakhenshield
i think im gonna do this tomorrow because its getting really cold outside..
i started looking for a bulb replacement at amzn and i dont know what to get because opt7 has 2 version DC and AC, in case the bulb is the prob.
Bruuuum Bruuuum!
Old 02-26-2015, 10:01 AM   #12
bhbnuckle
bhbnuckle's Avatar
Drives: 2013 Asphalt FR-S/2003 Honda Accord
Did you get it fixed?
bhbnuckle is offline   Reply With Quote
Old 02-26-2015, 08:27 PM   #13
ringo16
Drives: 15 Asphalt FRS
I was told by my friend that you should turn the HID on for at least a minute the first time and turning the bulb off/on too quickly can short the bulb. If you mess the bulb up it turns pink.
I got my kit from DDM Tuning. The price is right and they seem to work pretty good so far.
ringo16 is offline   Reply With Quote
GT86 headlights vs. Maserati Ghibli Headlights l0aded Scion FR-S / Toyota 86 GT86 General Forum 7 08-29-2014 09:39 AM
Trade FRS headlights for BRZ headlights? Teknian_Culprate13 Exterior Parts (Aero, Lighting, Etc.) 10 07-14-2013 09:11 PM
DDM HID Problem LinknLog Cosmetic Modification (Interior/Exterior/Lighting) 18 04-11-2013 01:43 PM
Problem Headlights after HID Install imravenit Cosmetic Modification (Interior/Exterior/Lighting) 2 09-30-2012 09:18 AM
