Old 07-10-2013, 05:41 PM   #1
Teknian_Culprate13
Teknian_Culprate13's Avatar
Drives: Scion FR-S
Trade FRS headlights for BRZ headlights?
will they even swap properly?
ill ship if some one is down?
Teknian_Culprate13 is offline   Reply With Quote
Old 07-10-2013, 06:00 PM   #2
5th 86
Drives: 2013 BRZ SPORT TECH
Who would be stupid nuff to go to all that trouble to devalue there brz, and make it less functional???
5th 86 is offline   Reply With Quote
Old 07-10-2013, 06:41 PM   #3
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Because racecar
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 07-10-2013, 07:32 PM   #4
FRSHunter
Drives: Asphalt FRS
"I would definitely trade my HID's for some Halogen headlights" - Said no BRZ owner ever
FRSHunter is offline   Reply With Quote
Old 07-10-2013, 07:40 PM   #5
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
They swap directly. Subaruonlineparts.com has them for sale. I believe most BRZ owners will kindly reject your suggestion.
AVodka14 is offline   Reply With Quote
Old 07-10-2013, 09:58 PM   #6
xDBOYx
xDBOYx's Avatar
Drives: 2013 SWP BRZ Limited
some might consider it with cash on top, but still gotta find that one BRZ owner that will
xDBOYx is offline   Reply With Quote
Old 07-10-2013, 11:01 PM   #7
AVodka14
AVodka14's Avatar
Good luck
Old 07-11-2013, 01:36 PM   #8
pche
Guy on internet
Drives: Slowly
Sure I'd love to, you ship first.
pche is offline   Reply With Quote
Old 07-11-2013, 02:06 PM   #9
nalc
Drives: 13 BRZ Limited 6MT GBS
It may be worth noting that while the BRZ and FR-S headlights are interchangeable, the FR-S headlights contain a low beam projector and a high beam reflector with the turn signal in a separate housing, whereas the BRZ headlights contain a single projector for lowbeams and highbeams, and a turn signal in the spot that the FR-S has the high beams.
So while it'd be quite possible for you to buy BRZ headlights and install them on your car and leave one pair of the turn signals disconnected, a BRZ owner with FR-S headlights would not have any turn signals, since the FR-S turn signals are not compatible with the BRZ bumper.
nalc is offline   Reply With Quote
Old 07-13-2013, 05:25 AM   #10
AVodka14
AVodka14's Avatar
Interesting enough. The advantage will go to the FRS owner with swapping to BRZ headlights. If you disconnect the turn signals (since you will have them from the BRZ headlights) the sidemarkers become turn signals. Someone found this out by disconnecting his turn signal on his FRS. BRZ headlight swap to FRS FTW!
Old 07-14-2013, 08:11 PM   #11
nalc
Sidemarkers can optionally flash as additional turn signals, but they are not a safe or legal replacement for the turn signals. That feature should be viewed as a something to allow at least some turn signal functionality in the event of a bulb burning out, while you work on finding a replacement, not as a license to remove your actual parking lights.
FS: OEM FR-S headlights iketiak Exterior Parts (Aero, Lighting, Etc.) 9 08-27-2013 11:49 AM
Wtb: Brz headlights DarkCard Exterior Parts (Aero, Lighting, Etc.) 0 06-01-2013 10:03 PM
Blacked Out Headlights Trade For Stock!! Shizzaw Exterior Parts (Aero, Lighting, Etc.) 27 05-14-2013 09:17 AM
WTB: BRZ/FR-S Headlights tdoggy57 Exterior Parts (Aero, Lighting, Etc.) 0 01-31-2013 12:23 AM
FR-S w/ BRZ headlights :) Carban FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 30 06-04-2012 11:19 PM
