#57 | |
Drives: Asphalt FR-S MT
That's a good bit of info. I had no idea Sent from my iPhone using Tapatalk |
#58 |
Or is it because the NA needs higher/free rev response so they've done more engineering to shave the weight on the internals?
#59 | |
The Mechanic
Drives: Civic Turbo,FR-S
#60 |
Drives: FRS-RS1, Triumph Speed Triple, Lola
#61 |
Drives: The silvertrooper 10 series
Stock block C38 KW supercharger at 19 psi, should be over 400hp, it gets dyno next week.. should be because the other KW C38 was doing 408 at 16 psi and i easily pulled on him.. both on E85 he had over 10k miles until a meeting with a K barrier ended everything, im over 5k so far no issues
Thomas |
#62 |
in orbe terrum non visi
Drives: violent
Your barking up the wrong tree. I have a case open pending legal action right now about a failed syncro warranty claim that was denied because a dealer claimed it was because of hp. I'm fully aware hp doesn't kill syncros.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#63 |
What is failing in the boxes that you have replaced?
#64 |
Drives: violent
I either shear 4th gear, or a syncro goes out. I've seen/replaced transmissions in other cars for a sheared 4th gear and a worn out 5th syncro and a worn out 2nd gear syncro. Same problems as me/fullblown/element tuning/don/synack and the list goes on.
#65 |
Drives: violent
I'm running an oil cooler now but I don't see temps hot enough for it to turn on.
#66 |
Drives: ft86
http://www.synchrotech-transmissions..._Synchros.html
maybe these guys can make some synchros for our gearbox? |
#67 | |
Drives: violent
And most of those are single cone honda replacements. Hence why they don't make one for the ap1 triple cone. It would cost more then what I paid for a used transmission.
#68 |
I would love to get an update on how that turns out!
#69 |
Drives: ft86
#70 |
| WTB FA20 Stock | Cross | Want-To-Buy Requests | 22 | 08-19-2014 02:59 PM |
| WTB FA20 Stock | Cross | Want-To-Buy Requests | 1 | 08-01-2014 06:47 PM |
| Stock FA20/trans, never modified 9k miles ATM - April/May | slicktop | Engine, Exhaust, Bolt-Ons | 2 | 02-24-2014 07:44 PM |
| Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? | Acree | Engine, Exhaust, Transmission | 2 | 08-26-2013 06:39 PM |
| Stock AISSIN Transmission Power Capacity | Don@Accelerated | Forced Induction | 37 | 07-03-2013 10:15 PM |
