Old 08-29-2014, 08:00 PM   #1
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Any idea to mount tablet on seat rail??
Hello, I have this tablet seat mount that gets hooked with the bolt on the seat rail.... If that made sense..
Anyways, how do I loosen the bolt on the seat rail? I know I need a LONG torque wrench and a special E-Torx wrench or something (E-10?)? How tight is it lol?
Or do you have any idea for this??? Check pic attached
Mikeez is offline   Reply With Quote
Old 08-29-2014, 09:20 PM   #2
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
It's pretty tight. Make sure you have the right fit socket for it and be careful.
Once removed you can replace with a "normal" head bolt to make it easier in the future. That's what I have done for my fire extinguisher mount using those bolts.
nzer is offline   Reply With Quote
Old 08-29-2014, 09:22 PM   #3
Grateful Dave
2nd 86 member
Grateful Dave's Avatar
Drives: 2013 Asphalt AT FR-S
just drive the car, don't worry about Fn tablets
Grateful Dave is offline   Reply With Quote
The Following User Says Thank You to Grateful Dave For This Useful Post:
nivek111070 (08-30-2014)
Old 08-30-2014, 11:03 AM   #4
Mikeez
Engineering Student
Thank you for the help, but what kind of wrench you used?
For the second person, I want to mount the tablet.
Old 08-30-2014, 03:29 PM   #5
nzer
nzer's Avatar
Nearly missed this question @Mikeez - remember to tag as there's so many posts on this forum.
I used my large torque wrench with an adapter to fit the small socket.
Old 08-30-2014, 06:48 PM   #6
aagun
Drives: 86
mine loosen up and i use TIG welding with other nut to remove it .
aagun is offline   Reply With Quote
Old 08-30-2014, 06:58 PM   #7
Fastbrew
Drives: 2014 Pearl White BRZ
Yo - just out of curiosity - do you have a link to a pic of how this thing will be positioned after you get it done? I have a cafi android unit mounted in my dash but I am curious how this will look.
Thanks and gl!
Fastbrew is offline   Reply With Quote
Old 08-31-2014, 12:38 PM   #8
Mikeez
Engineering Student
Oh alright and sorry about this.
Thank you I will try to do that xD
Thanks and gl!
If you want, once it's done I'll make a journal and tag you?
Old 09-03-2014, 12:20 AM   #9
westendRIOT
Drives:
I've been there with this mount. The pesky security bit came out (carefully) with a standard hex. Then I realized the forked tongue is too fat to fit in the dimple of the seat rail.
I didn't feel like adding washer spacers to get up out of the hole, along with a longer bolt to compensate for the lost threads so...
Second choice: Passenger footwell side of the front center console. Pop off the plastic trim piece to reveal a few eligible bolts. I think they were all standard hex.
Be careful bending the pipe of the mounting arm. It's strong but can fatigue and break if you abuse it.
GL!
westendRIOT is offline   Reply With Quote
Old 09-03-2014, 12:40 AM   #10
hypercarfanatic
Drives: Own F-150XLT, Lexus RX300
Subbing because I want to do the exact same
Is it bad that I don't have the car, yet am planning out the thousands in mods that I want? Nahhhh
hypercarfanatic is offline   Reply With Quote
Old 09-08-2014, 12:28 PM   #11
Mikeez
Engineering Student
GL!
I'm not very familiar with the words haha, whats the front ceter console? Isn't it the one next to the passenger seat?
How to remove seat rail bolt after you've stripped it protpibe DIY (Do-It-Yourself) Guides 33 02-01-2020 02:06 PM
Remove seat rail bolts existensil Cosmetic Modification (Interior/Exterior/Lighting) 12 06-09-2014 04:20 PM
Passenger Seat Rail Plastic End Piece Off skyre Issues | Warranty | Recalls / TSB 4 12-04-2013 10:56 PM
need help unbolt seat rail bolt chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 2 07-01-2013 10:06 AM
Another seat rail option! Nagisa Auto Seat Rails vividracing Cosmetic Modification (Interior/Exterior/Lighting) 11 02-28-2013 04:15 PM
