Old 06-02-2014, 01:42 PM   #1
existensil
existensil's Avatar
Drives: 2014 BRZ Limited
Remove seat rail bolts
I would like to remove the bolts holding down the seat rails. They appear to be E-TORX bolts. Does anyone know the size?
An 8mm socket/wrench seems to fit pretty well, so I tried that first. The bolts clearly have thread locker or something on them. I used a standard size 8mm wrench, and even used the two-wrench leverage trick, and was unable to get enough leverage to break the seal.
Could someone who has removed these tell me how they did it? I ordered a breaker bar, but not sure if that is enough and if I can get away with an 8mm socket without stripping the E-TORX.
I am trying to mount a custom fire extinguisher brace to the front bolts of the passenger seat so I can take my car on the track.
existensil is offline   Reply With Quote
Old 06-02-2014, 01:46 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
8mm socket with extension and large ratchet.
Old 06-02-2014, 02:28 PM   #3
jonzhuxD
Drives: Ultramarine FR-S
E-10 Torx Socket with a breaker bar.
jonzhuxD is offline   Reply With Quote
Old 06-02-2014, 05:15 PM   #4
Chimera
Drives: FRS
E-10, don't need the breaker bar, its doable by hand, I did.
Old 06-07-2014, 10:43 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
^ not spin-able by hand, but just a standard socket wrench
that was how i got mine off..
Old 06-08-2014, 03:55 PM   #6
Tuan
Tuan's Avatar
Drives: Whiteout FRS
Send a message via AIM to Tuan
You'll strip the bolts this way. Use an E10 torx socket - you may need a breaker bar if you don't have enough leverage.
Tuan is offline   Reply With Quote
Old 06-08-2014, 06:29 PM   #7
Estey
Drives: Scion FR-S, Ultramarine
don't use anything other than an e10 torx socket. I made that mistake and rounded off the bolt head behind the seat and now its a huge headache to get out. I kind of screwed myself, lol, but you live and learn I suppose. If anyone knows of a way to get this bolt out, any advice would be greatly appreciated. Its just so cramped and theres no room because of the rails.
Estey is offline   Reply With Quote
Old 06-08-2014, 06:32 PM   #8
Lord Peth
Drives: 2014 BRZ
probably just go to the dealer and order a new on and CAREFULLY grind off the stripped one
Lord Peth is offline   Reply With Quote
Old 06-08-2014, 06:40 PM   #9
Estey
Before attempting to get it off, I went to ace hardware and matched the bolt so that I could fasten the seat down once I got it off, but I do intend to order a new one eventually.
what do I do once I grind the bolt head off? the dremel head is too big to get inbetween the rails. but I tried easy-out and it failed. I also tried hammering on a socket to see if I could gain some leverage and muscle it out, but that hasn't worked. so im kind of stuck
Old 06-09-2014, 08:50 AM   #10
jonzhuxD
Use a dremel and a cutting wheel to cut a slot into the bolt, then use a flathead on a socket and get it out carefully
Old 06-09-2014, 09:28 AM   #11
KDad2
KDad2's Avatar
Drives: 2013 Raven
Here's another thread that might also work.
http://www.ft86club.com/forums/showthread.php?t=54722
KDad2 is offline   Reply With Quote
Old 06-09-2014, 12:07 PM   #12
Chimera
Drives: FRS
I rounded off one of mine too be using a regular socket before getting an e10
I just hammered the socket onto the bolt and it reformed enough to be removed.
Old 06-09-2014, 04:20 PM   #13
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
You NEED a quality E10 Torq socket as well as "heat" aka micro torch. I dealt with this in a difficult way myself so just sharing. If you pre heat bolts abit then bang on solid a E10 Torq socket with a long bar and use gentle power should be no issue. Easiest way if you strip one to remove is a extraction socket.
I went through all this a few months back myself
http://www.ft86club.com/forums/showthread.php?t=52845
How to remove seat rail bolt after you've stripped it protpibe DIY (Do-It-Yourself) Guides 33 02-01-2020 02:06 PM
Seat rail bolt part number? nalc Cosmetic Modification (Interior/Exterior/Lighting) 5 12-05-2013 10:16 AM
Passenger Seat Rail Plastic End Piece Off skyre Issues | Warranty | Recalls / TSB 4 12-04-2013 10:56 PM
need help unbolt seat rail bolt chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 2 07-01-2013 10:06 AM
Another seat rail option! Nagisa Auto Seat Rails vividracing Cosmetic Modification (Interior/Exterior/Lighting) 11 02-28-2013 04:15 PM
