Old 07-24-2014, 05:04 PM   #15
Stratoside
Stratoside's Avatar
Drives: Firestorm red MT FR-S 2013
does it hurt the transmission if I don't wait for it to warm up?
Stratoside is offline   Reply With Quote
Old 07-24-2014, 05:18 PM   #16
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
No.
I like the clunk. Means shit is happening.
Jyn is offline   Reply With Quote
The Following 6 Users Say Thank You to Jyn For This Useful Post:
extrashaky (07-24-2014), finch1750 (04-29-2016), pascalbrax (07-25-2014), strat61caster (07-24-2014), Teseo (07-24-2014), virobloc (07-26-2014)
Old 07-24-2014, 05:36 PM   #17
mankarn86
Drives: 2007 Altima 3.5 SE 6sp
Guys I find it helps to double clutch the first couple shifts for second gear when the car is cold. Then you avoid the clunk altogether. When I say double clutch I mean shift to neutral first, blip the gas a bit and then shift to second as opposed to first directly to second.
This worked very well for me in -40 C Canadian weather this winter.
mankarn86 is offline   Reply With Quote
The Following User Says Thank You to mankarn86 For This Useful Post:
Old 07-24-2014, 06:00 PM   #18
Frozen_skidmark
Frozen_skidmark's Avatar
Drives: Whiteout FRS
I think this is the best thing anyone's ever said about this transmission ever. I think if you accept that you can go on and live your life and be happy. Lol!
2014 Whiteout FRS
Frozen_skidmark is offline   Reply With Quote
Old 07-24-2014, 06:17 PM   #19
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
I've driven 911s that have clunkier transmissions. I like the clunky FRS transmission. Provides a nice mechanical feel.
Braces is offline   Reply With Quote
Old 07-24-2014, 06:56 PM   #20
PB86SS
PB86SS's Avatar
Drives: Sonic Blue MT GTS 86
My baby turned one this week, and she is slowly becoming smoother to shift from first to second. It's winter here though, so during cold starts I've found that hesitating slightly before shifting down into 2nd seems to help a lot:
1st gear / clutch in / shift half way to 2nd for a half second / shift fully to 2nd / release clutch
As someone mentioned above, using higher revs than normal does help but I don't like doing that while she's warming up.
PB86SS is offline   Reply With Quote
Old 07-24-2014, 07:24 PM   #21
Jyn
Noob
Jyn's Avatar
This is the first M/T car I've owned. It scared me at first, but now it's nice. I am, indeed, pretty happy with it
Old 07-24-2014, 10:14 PM   #22
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
the 1-2 doesnt really get better and is always annoying. Just try to forget it and get used to it.
lickitysplit is offline   Reply With Quote
Old 07-25-2014, 07:32 AM   #23
rs999
rs999's Avatar
Drives: VW MK6 GTI | 13 Mustang GT
I have 1 down but I still have the habit of over-revving in 1.
In the 1-2 transition I still drop the clutch too fast and buck the car.
Yesterday I tried driving aggressively on a back road and missed the 4-5 transition and instead went to 3 and over-revved. Then I did it again missing 5 completely and just over-revved in neutral.
Learning MT is the pits.
SOLD FR-S Build | MK6 GTI Build | I might be getting another FR-S
rs999 is offline   Reply With Quote
Old 07-25-2014, 11:18 AM   #24
Ubersuber
Drives: BRZ Pearl White
You'll be comforted to know there is a rev limiter preventing over revving in neutral or by use of the gas pedal. You can only over rev by downshifting too early and letting the clutch all the way in.
You can damage the engine by overrevving it even with no load as maximum load on the conrods is reached at TDC on the exhaust stroke, when both valves are open and the piston reverses. Most conrod failure occurs then. Also, above a certain rpm the valves begin to float on their springs and contact between the piston face and the valve heads is possible, again most likely at TDC on the exhaust stroke.
Two things: never, ever over rev your engine and fortunately this particular engine will suffer no damage if you over rev it only a little bit, apparently, and don't ask me how I know this.
It seems very likely this engine is designed to accept a red line of over 8,000 rpm before it becomes a boat anchor. In fact, the easiest way Subaru could develop more power is by raising the redline. This is one of the few engines I have driven recently (other than a Porsche or Ferrari) that seems perfectly willing to pull through its reasonably high redline so there's more to be had above 7,400 rpm with a proper cam profile.
Ubersuber is offline   Reply With Quote
Question about A/T using it in Manual mode Oburn Engine, Exhaust, Transmission 46 07-07-2022 06:40 PM
Auto trans manual shift question.... Tromatic Engine, Exhaust, Transmission 18 05-24-2015 11:00 PM
Manual Transmission Question calidus BRZ First-Gen (2012+) — General Topics 4 06-21-2014 05:20 PM
Question for the experienced manual drivers.. enjoi23 Scion FR-S / Toyota 86 GT86 General Forum 54 10-18-2012 05:38 AM
TRADE: my Silver GT Manual (October Delivery) for Pegasus White GT Manual -AUSTRALIA ysagisan Cars for Sale/Trade 0 09-19-2012 12:24 PM
