Old 05-17-2013, 03:10 PM   #1
Tromatic
Auto trans manual shift question....
The tC I had previously would remember the highest gear you were in when manually shifting after coming to a stop. You could accelerate away from a stop, and if you had been in third, it would upshift back to third.
I don't see anything in the manual that woul allow you to have the FR-S do this. Is it possible? I'll read it yet again, just in case.
Tromatic is offline   Reply With Quote
Old 05-17-2013, 03:51 PM   #2
Simpleviet
Right Foot Flat
Simpleviet's Avatar
Drives: Asphalt Lucille
I'm not sure if you noticed or not but as you speed up or slow down there are arrows up and down that tells you to shift up or down. I hope that helps you
Simpleviet is offline   Reply With Quote
Old 05-17-2013, 03:54 PM   #3
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
On the AT it shifts back down to the gear most applicable to the speed. So if you are in manual and come to a stop sign it will shift down to 1st. It will not (at least mine does not) down shift itself while in manual, except when you stop. I enjoy the paddle shifters for down shifting, the auto blip helps control your gears when in manual.
Spartan65 is offline   Reply With Quote
Old 05-17-2013, 03:58 PM   #4
ramiram1984
Drives: 2016 STi DGM
Calling all ATs out there.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 05-17-2013, 08:58 PM   #5
Tromatic
Perhaps I did not make myself clear: 1. In a Scion tC RS-8, step on gas, manually shift the AT into (for example) third gear. 2. Decelerate. The AT will downshift, winding up in first at a stop. The number 3 remains on the digital gear indicator. 3. Accelerate. The AT will upshift from one to three. IOW, it remembered the highest gear you manually selected. You could also select a gear while stopped (fourth, for example) and it would upshift to fourth and stop there. Can you get the FR-S to do this? Why would you want to? Why not?
I use my ears for for that.
Old 05-17-2013, 09:32 PM   #6
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
No it does not thank god. That sounds horrible. Why would you want that?
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 05-17-2013, 09:33 PM   #7
DR 86
DR 86's Avatar
Of course it will downshift itself in manual; what it won't do is upshift itself, even if you bounce off the rev limiter. If it doesn't downshift as rpms drop with decreasing speed, the engine would stall. For example, you're in manual mode, driving 70km/h in 6th, you brake to slow down for a turn. As you're speed drops to around 58km/h, the transmission will automatically downshift to 5th. As you're speed drops below 50km/h it will downshift automatically to 4th and so on.
Why wouldn't you want to car to remember the highest gear and automatically upshift for you? Simple: how would it know at what rpm to upshift each gear from 1st to 2nd to whatever gear you were in when you stopped? If I wanted to car to automatically upshift, I would have it in auto mode. The whole point of manual mode is so I can (if I wanted) throttle it to redline before upshifting to a higher gear and increase access to torque and horsepower.
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
DR 86 is offline   Reply With Quote
Old 05-17-2013, 09:34 PM   #8
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
I had an auto 2011 tc and i know what you mean. If you were in 3rd and come to a stop, itll stay lit as 3rd as it downshifts and when you go again itll upshift only to that gear automatically. The frs is more manual in manual mode if you will. If you come to a stop itll go back to 1st automatically and you have to upshift every gear. This is normal. I had the auto frs at first before trading for the mt brz and i had to try to remember to upshift every time lol
abutterman is offline   Reply With Quote
Old 05-17-2013, 09:36 PM   #9
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Doesn't sound like manual mode if you ask me.
Thank god that's not on the FRS...
Old 05-17-2013, 10:58 PM   #10
Tromatic
I can think of a couple of situations where it would be handy to have the FR-S do that, just like it was in the tC. So is the answer "no, the FR-S won't do that and I'm glad it won't because that's stupid" or "I don't know"? It's obviously a shifter software solution, and it would be cool to have the option.
Old 05-18-2013, 12:15 AM   #11
Simpleviet
Right Foot Flat
Simpleviet's Avatar
I never knew that. I had thought you would need to downshift as well as upshift under manual mode. Good to know. Thanks.
That's good.
Old 05-18-2013, 12:21 AM   #12
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
the at in M mode will down shift if the rpm's get too low but will never upshift until you tell it to even at the rev limiter (ive forgotten i was in manual mode one)
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 05-18-2013, 02:40 AM   #13
Fast_Freddy
Drives: Passat
Maybe one day a Japanese manufacturer will get it right again as Mazda did on my old '88 626. Manual mode was manual mode and if you coasted to a stop in 3rd gear, 3rd gear is where it stayed until you changed it. I too dislike the way my FRS downshifts for me in "manual mode".
As far as changing the current programming, I highly doubt that it is an option. It's possible but will probably never be offered by Toybaru or the aftermarket.
Fast_Freddy is offline   Reply With Quote
Old 05-20-2013, 12:17 AM   #14
DR 86
DR 86's Avatar
Some examples of said situations please.
FRS/BRZ Manual Trans Fluid shellslinger Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 131 11-02-2017 10:44 AM
Auto Trans paddle shift issue Craig Issues | Warranty | Recalls / TSB 26 08-17-2015 10:00 PM
FS: 1st 86 DGM/Asphalt Scion FR-S (Manual Trans) Neurytic Cars for Sale/Trade 3 05-22-2013 11:54 PM
AT Trans Shift Knob Replacement sapphire Cosmetic Modification (Interior/Exterior/Lighting) 7 11-14-2012 11:08 PM
Got a line on two unclaimed BRZs (manual trans) Tainen BRZ First-Gen (2012+) — General Topics 0 07-05-2012 10:40 PM
