Old 06-18-2014, 01:00 PM   #1
calidus
Drives: 2013 SWP BRZ Premium
Manual Transmission Question
Sometimes you get those really buttery smooth shifts and other times it feels "notchy." When you move the shifter and you feel resistance shifting into a gear, what are you actually feeling?
calidus is offline   Reply With Quote
The Following User Says Thank You to calidus For This Useful Post:
Purdue FR-S (06-18-2014)
Old 06-18-2014, 01:07 PM   #2
strat61caster
strat61caster's Avatar
You're feeling the synchros slowing down or speeding up the input shaft of the transmission to match the output shaft based on the gear ratio you've selected.
Double clutching just right eliminates the resistance you feel caused by the synchros matching the shaft speeds and the lever will practically fall into place. In practice though it's not usually worth the extra effort, the synchros are doing their job.
Shifting slower should reduce some of the resistance you feel as well as prolong the life of the synchros, let it slide into gear instead of jamming it.
Edit: I'm not 100% sure on the notchiness factor, like it 'chunks' going into third for me sometimes so I don't want to say anything incorrect on that front.
Edit 2: Quickly found this post:
An occasional non-smooth engagement is normal. You've got spinning metal things with teeth that need to get jammed into holes to stop the spinning...the synchronizers do a good job of matching everything up but can't do it perfectly every time, sometimes teeth will miss their hole for a moment before catching.
Seems good to me.
http://www.standardshift.com/forum/v...p?f=10&t=14659
ineedyourdiddly
calidus (06-18-2014)
Old 06-21-2014, 03:07 PM   #3
Sleeperz
Drives: 1982 Toyota Corolla Coupe SR5
Check for clutch drag. A dragging clutch can kill your transmission within only a few shifts as the synchros are fragile. It doesn’t matter what they are made of or if they are double or triple synchro, they will be ruined if the clutch drags, period.
http://www.jackstransmissions.com/pa...kills-synchros
Sleeperz is offline   Reply With Quote
The Following User Says Thank You to Sleeperz For This Useful Post:
calidus (06-23-2014)
Old 06-21-2014, 03:11 PM   #4
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Does this help?
It helped me.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
The Following User Says Thank You to SmartedPanda For This Useful Post:
Old 06-21-2014, 05:20 PM   #5
stugray
Drives: 2013 GBS BRZ Limited
I would not say that statement is true.
I have shifted my trans literally hundreds of times with NO clutch, and it is fine.
But yes a dragging clutch can make poor shifts hard on the synchros and will wear things out faster.
Most of the time we feel a grind when shifting is because we are not fully disengaging the clutch.
That is a result of making very smooth shifts most of the time by rev matching.
Then our habits develop to just barely press the clutch enough
The Following User Says Thank You to stugray For This Useful Post:
Has anyone had a Manual transmission apart? SilverSRTSedan Engine, Exhaust, Transmission 9 03-23-2014 09:05 PM
Manual transmission 2nd into 1st MrMista Engine, Exhaust, Transmission 9 10-13-2013 11:48 AM
Second Impression with a Manual Transmission Bristecom Scion FR-S / Toyota 86 GT86 General Forum 22 08-30-2012 09:21 PM
Which transmission do you have ? Manual or Automatic ? PRO Import Tuners Engine, Exhaust, Transmission 14 08-24-2012 10:21 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 08:54 PM
