Old 07-10-2014, 06:14 PM   #1
slowbrz
Drives: '13 black BRZ MT
No coolant light
I noticed I have no more coolant in my coolant container but why hasnt my low coolant light turned on? Is it normal for coolant to fully drain after 1.5 years of having the car? I only have 16k miles
slowbrz is offline   Reply With Quote
Old 07-10-2014, 06:19 PM   #2
bjun
bjun's Avatar
Drives: white premium brz M/T
my coolant seems to disappear after few thousand miles too. i think it's normal on 86 bc i don't see/smell any leaks
Mine goes empty 5-10k miles
bjun is offline   Reply With Quote
Old 07-10-2014, 06:20 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
1) because your system is still full...
2) it does need to be replenished regularly (the overflow tank)
[ame="https://www.youtube.com/watch?v=V7inC4lOpGs"]How Car Cooling System Works - YouTube[/ame]
-alex
number1Tango (09-23-2014)
Old 07-10-2014, 06:22 PM   #4
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
There's no low coolant light. You'll just see your coolant temp gauge go really high or the ECU will throw a CEL for low voltage on coolant temp sensor if it's dangerously low. If not just top off with Subaru/Toyota OEM BLUE coolant or distilled water and should be good to go. Reason I know is I've had my engine nearly overheat twice due to a leaking radiator where it was dumping coolant.
JDKane527 is offline   Reply With Quote
Old 07-10-2014, 06:24 PM   #5
slowbrz
My temp gauge has been looking normal. I wasnt aware this car doesnt have a low coolant light.
Old 07-27-2014, 01:31 AM   #6
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Did you also know there's no maintenance light? LOL
N1rve
Old 09-22-2014, 08:24 PM   #7
07jazzrs5gt86
Drives: Firestorm 86
What kind of coolant be used?
I just notice the reserve tank is empty so i was planning on getting peak coolant
07jazzrs5gt86 is offline   Reply With Quote
Old 09-22-2014, 11:31 PM   #8
JB86'd
JB86'd's Avatar
Drives: JAWS
Can you not read 3 posts above yours?
JB86'd is offline   Reply With Quote
Old 09-23-2014, 12:12 AM   #9
Estey
Drives: Scion FR-S, Ultramarine
Just top it off with distilled water. It seems that the water is evaporating from the coolant reservoir, so the concentration of coolant remains the same. If you added more coolant it would just create a higher concentration
Estey is offline   Reply With Quote
low coolant BRZPDX Northwest 17 06-06-2015 02:42 PM
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 07:34 AM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 06:56 PM
is my coolant low? chenshuo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-20-2013 12:43 AM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 01:03 PM
