Old 04-26-2014, 04:55 AM   #1
Thunderleg
Thunderleg's Avatar
Drives: Black BRZ
WedsSport SA70 C-One 17x8.0 +32
I just ordered rims - 17x8.0+32. Will I need spacers for a flush fit?
Thanks!
Thunderleg is offline   Reply With Quote
Old 04-26-2014, 08:35 AM   #2
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Thanks!
Those wheels should be pretty close to flush already. Fit the wheels first then see how much gap you have. Then you can decide on your spacer size
Fizz is offline   Reply With Quote
Old 04-26-2014, 08:56 AM   #3
Thunderleg
Thunderleg's Avatar
Drives: Black BRZ
That's what I planned on, I was just hoping someone with an extensive knowledge in the area would chime in and say "a XX spacer would be perfect"..
Thanks
Old 04-26-2014, 09:05 AM   #4
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
The front will be close. The rear will need like 8-10mm
Old 04-26-2014, 09:19 AM   #5
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Thanks
By the way anything more than 3mm will require longer studs. Many will say 5mm on factory stud is still ok, but I don't like taking chances. I also highly recommend getting custom made hub and wheel centric spacers. Well worth it.
Old 04-26-2014, 09:46 AM   #6
BlueDubbinTDI
I have brand new longer studs I can sell you
Old 04-26-2014, 10:11 AM   #7
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
What length?
Old 04-26-2014, 01:30 PM   #8
BlueDubbinTDI
What length?
I dont know exactly, they came with 5mm H&R spacers. So enough for an 8 mm spacer. Which would be ideal for this setup.
Old 04-27-2014, 05:01 AM   #9
Thunderleg
Thunderleg's Avatar
Drives: Black BRZ
Thanks guys. @BlueDubbinTDI PMed you
Old 05-08-2014, 07:55 PM   #10
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
I don't have any wheels with those specs in the Wheel Directory... have you installed them? What brand/model are they?
Old 05-13-2014, 12:36 AM   #11
Thunderleg
Thunderleg's Avatar
Drives: Black BRZ
WEDS sa70 C-one edition. I'll post some pictures when I get them on.
The Following User Says Thank You to Thunderleg For This Useful Post:
DarrenDriven (05-13-2014)
FlushBrz's Flush FR-S. lol FlushBrz Member's Car Journals 40 02-08-2014 09:35 PM
RPF1 most flush? goshem Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 11-27-2013 11:34 AM
Gas cap cover not flush with body? CrazyWookiee Scion FR-S / Toyota 86 GT86 General Forum 3 08-19-2012 11:32 PM
Flush +/- DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 08-13-2012 12:37 PM
Help with DIY transmission flush. ahausheer Other Vehicles & General Automotive Discussions 0 06-26-2012 04:51 PM
