Old 04-11-2014, 10:12 PM   #15
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Yeah, idle. Run the revs up.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
^GT5 Replay Photo Mode^
Old 04-14-2014, 02:44 PM   #16
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Originally Posted by AtlasMick View Post
Just got the Mike Singer 275A alternator last night, by hand it didn't feel all that much more difficult to spin. I see what you are saying. I'll have to ask how it's done.
Just got word back from Nations Auto Electric:
Should be doable..... The cover over the front of the alternator doesn't let me
see the full mounting configuration... We may have to have one to match everything
up. But, again, where it's located shouldn't make it hard to retrofit a high amp solution.
I would either need a vehicle or an alternator.
Thanks,
Adam Nations
Nations Starter & Alternator
2210 Broadway
Cape Girardeau, MO 63701 USA
(t) 573-334-2632
1-888-334-2632
www.nationsautoelectric.com
Is there anyone in the Midwest that would be willing to volunteer for measurement and/or test fitting?
I'd gladly be the test mule for this one if this weren't my DD and only vehicle.
If there are spare alternators laying around, this would be a huge benefit to the community. I'm sure we could cover any round-trip shipping costs incurred.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 04-20-2014, 05:40 AM   #17
brianhj
Drives: 2017 Camaro 1SS
DC Power are about the only high amp alternators I've seen that don't sacrifice low rpm (idle) amperage. All the others usually output lower idle amps than stock alts, so you only see the higher "rated" output at higher rpms
brianhj is offline   Reply With Quote
Old 06-22-2016, 09:47 AM   #18
driftking96
Drives: 2014 Scion FR-S, 1998 Honda Accord
For those of us running or looking to run massive amperage drawing systems, what alternator options are you considering?
I haven't seen any increased amperage alternators for the FR-S/BRZ/GT86.
Does anyone have a link to the stock max alternator output?
Some considerations:
Smaller diameter pulley on the alternator
Dual alternator installation
Replace with higher output ALT.
Any other suggestions?
Can you please tell me your sound system setup if that is indeed the source of massive power draw? Trying to figure some audio stuff out as well.
Sent from my ONE A2005 using Tapatalk
driftking96 is offline   Reply With Quote
Old 03-24-2020, 07:52 PM   #19
AtlasMick
Drives: FR-S 2013 Asphalt
I was running close to 3300watts. I used Singer but the alternator itself didn't seem to put out that much more power. I think a better custom solution would have been better. Maybe a larger truck alternator, but even with a custom case with mounts that will adapt to the frs motor would still require a new longer accessory drive belt.
So, you can get a little extra power from an upgraded alternator, but don't depend on it, even though you will need it. Combine it with larger/multiple batteries that are for audio and definitely run capacitors.
AtlasMick is offline   Reply With Quote
Old 08-18-2021, 04:02 PM   #20
dethzombi
Drives: Neptune Blue A6
I don't have any experience with these cars, but I used to run 4 12's on 3,000 watts in an 01 Tahoe and later 4 12's on 10,000 watts, one 250a alternator is not enough. I had 2 320a alternators, everything wired with 1/0 ofc wiring, and a couple of these batteries NorthStar SMS-AGM480's. Buuuuuut, with all that said, 3,300 watts seems like way too much for how small this car is. I was looking at max like 800 watts to go in my wife's 86.
dethzombi is offline   Reply With Quote
Alternator pulley torque setting?? ahaghshenas Engine, Exhaust, Transmission 4 07-27-2014 09:03 PM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 01:53 PM
Carbign Craft Alternator Cover BugeyedWagon Cosmetic Modification (Interior/Exterior/Lighting) 12 01-04-2013 10:58 AM
Alternator pulley?? xpicer Scion FR-S / Toyota 86 GT86 General Forum 2 10-13-2012 09:54 AM
Weak battery or bad alternator from factory? empower-auto Issues | Warranty | Recalls / TSB 2 09-21-2012 03:17 PM
