Old 01-11-2014, 06:02 PM   #141
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Anyone care to take a peek at my first pull with the 1.42b Stage 1 tune? ~162 seconds is a 0-62 run (check the throttle) and the 300 seconds chunk is a 3rd gear pull (Once again, check the throttle because it started on an on road and I was cruising slowly so that I could maintain low RPM before going WOT.
http://www.datazap.me/u/luckrider/14...ge-1-first-run
Luckrider is offline   Reply With Quote
Old 01-12-2014, 02:11 AM   #142
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Can anyone speak to the OFT tune with daily driving after a full exhaust swap? I'm thinking this will be the path I take but I wanted to hear some other impressions. (And yes I've read good bit of the thread already)
the new guy is offline   Reply With Quote
Old 01-12-2014, 08:01 AM   #143
troek
troek's Avatar
Drives: 2012 Toyota 86
Originally Posted by bfrank1972 View Post
Has anyone tweaked Shiv's 1.42 ots stage 1 map for 93 yet? Pretty sure all the OTS maps are tuned for 91, and I'm thinking We could squeeze a little more out of the stage 1 map if optimized for 93. If not I'm planning to give it a shot. Going to start by comparing stage1 timing tables to the stock timing tables, multiply the differences by a small amount, and apply to my new 93 map. Check knock and incrementally repeat. When I do see knock, pull timing 1/2 degree and re-check.. Seem like a sound approach? Any other advice? I'm a software engineer so I know how to approach things empirically, but I'm learning so any tips would be greatly appreciated.
Sent from my iPad using Tapatalk - now Free
i planned on doing something similar at some point. is this the only value we can take advantage of with higher octane?
troek is offline   Reply With Quote
Old 01-12-2014, 02:27 PM   #144
Kodename47
Kodename47's Avatar
Drives: UK GT86
Well I'd advise only touching one of the timing tables, whether it be base or advance that's up to you. I also like the idea of flat advance tables across each load so you can easily see if there's any timing being pulled, but that's just me.
@troek timing is the only thing that changes with differences in octane as you can run more advance with better fuel. The target AFRs won't change, unless the AFRs appear to be changing as a result.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-12-2014, 02:42 PM   #145
bfrank1972
Drives: 2013 FR-S Argento
Changing timing drastically can affect other things, but this operation should be a very minor increase in the base timing tables as there's not a huge difference between 91 and 93 - though I'd expect there'd be enough room to gain a few hp without running on the ragged edge. I've created a preliminary map by creating deltas (in Excel) between the factory map and Shiv's 91, then multiplying those values with deltas > 0 by a value so the largest deltas increase by 1/2 degree timing. I plan on doing these increments until logs start showing consistent knock, then I'll go back to the prior map (move back 1/2 degree for breathing room). I haven't really started testing because the temptation to run E85 got the best of me this week Once I get around to playing around more with my test 93 maps I'll post my results.
Old 01-12-2014, 04:12 PM   #146
troek
troek's Avatar
i look forward to it. ill be placing the order for my OFT pretty soon.
Old 01-13-2014, 11:09 PM   #147
TM
TM's Avatar
Drives: DGM BRZ 6MT
Is the soft rev limiter feature still in this 1.42 stock tune? If so, what exactly does it do?
I remember when I had 1.34 and rev'ed up to the limit, it kept my rev at the limit instead of bouncing back down. I just got a new BRZ and uploaded the 1.42 stage 1 tune to it and I thought I'd rev it up to make sure the tune was written correctly, but it cut off power and my needle bounced off the rev limit! I checked the vehicle rom info and it says stage 1.
TM is offline   Reply With Quote
Old 01-13-2014, 11:40 PM   #148
Luckrider
Luckrider's Avatar
LC is set to delta 2000 in the OTS tune. That seems to activate the factory style rev limit and cuts in at 5500RPM.
Old 01-14-2014, 09:22 PM   #149
Luckrider
Luckrider's Avatar
I've gotta say, I am really enjoying the OFT. In the stock car, power delivery was much improved with 93 and my logs seemed to be spot on ideal. I even picked up ~3mpg. I just switched to the 1.42b EL e85 tune with some corn juice and it must be high e stuff because I couldn't make it 1/2 mile without the fuel trims jumping. After about 2 miles I had to pull over (ahead of my preplanned stop) to flash because I could feel the loss in power and changes in timing. With corn juice it is just wonderful. The car would be amazing if it came like this. I'll get my first e85 log up later. I couldn't do a full 0-60 or full 3rd gear pull because I was on backroads, but the power was sweet. I couldn't open it up all the way like I normally can because of the wet roads.
Old 01-22-2014, 04:32 AM   #150
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Premium grade gasoline must be used. E85 fuel must be used for E85 designated tune files....
How do I know which files are for e85 and which ones are for premium gasonline?
Thanks.
Carlitoz3 is offline   Reply With Quote
Old 01-22-2014, 05:49 AM   #151
Luckrider
Luckrider's Avatar
Thanks.
e85 maps are marked in the tune name. It is premium gas unless otherwise noted.
Old 04-07-2014, 08:26 PM   #152
jupillam
jupillam's Avatar
Drives: White out Scion Frs
Originally Posted by Terrapin77 View Post
So instead of admitting defeat & going back to 93, I increased the cranking tables in my map by 10 to 20 percent. I did this to the all coolant levels 32 & below. It's 20 degrees in Atlanta right now and the car started on the 1st try. It did gurgle a little bit but at least it started right up. Here is a screenshot of my cranking tables
thanks for doing this,
my question is do i have to change "Cranking Fuel IPW Compensation A (RPM) Engine Speed (RPM)" to all "0.0"?
THanks
jupillam is offline   Reply With Quote
Old 10-17-2014, 01:52 PM   #153
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by mkivsoopra View Post
I've been having lots of cold start issues ever since I started using the E85 OTS maps. It would typically take 5-7 starts every morning to get the car running. Thanks to @Malt and @Terrapin77, I used their values and adjusted the values in the temperature range that's typical for my area (40-65F) this time of the year.
This morning, I was able to start my car on the second crank with a coolant temp of 62F. Gonna keep experimenting to see if I can get it to start on the first.
FWIW, I'm using 100% Propel E85, which measures 78-80% ethanol on my Zeitronix gauge.
Disclaimer.. use at your own risk blah blah blah.
Question: On tables A and F, why do the values go up then abruptly drop back down and start climbing again? Shouldn't they be a steady climb up?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 10-17-2014, 01:58 PM   #154
mkivsoopra
Yes.. ideally. Those numbers posted above were still a work in progress, and I was really only concerned about 32+ F degrees, since it will never get to 14F where I am. Tweak till it works for you.
mkivsoopra is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet E85 (and gasoline) Maps now available Shiv@Openflash Software Tuning 401 08-13-2014 11:14 PM
OpenFlash Tablet: new v1.40b maps, new website, new sales, oh my Shiv@Openflash Software Tuning 122 12-14-2013 10:17 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
