Old 04-07-2014, 12:48 AM   #29
nelsmar
Originally Posted by frs87 View Post
the fuel pump was good well i think it was but there was no way for me to tell im no mechanic, the car pulled crazyyy, that didnt feel like 7 psi, the boost controller wasnt messed with at all, and my mechanic did mention somethin about lowering the compression to about 9 or 10 to run higher boost and getting stronger rods and pistons, i have 550 injectors and running the gt28 turbo, the tune loaded fine but i didnt have any of my racerom features at all, like 2step etc etc which wasnt my main concern, i babied the car as much as possible but that didnt work so i guess i will see the results tommorow after they take the engine apart, and i was on 93 premium, i was gonna send lj the log but my car didnt even last 3 hrs before the knocking took place which really sucks,
How about posting the log here, or emailing it to me? I'll pm you my email. You are jumping the gun on a number of possible issues when the simple issue will be shown in the log...
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
s2d4 (04-07-2014)
Old 04-07-2014, 12:49 AM   #30
frs87
Drives: red/black
i dont remember what my wot afr was but i will upload my logg from my ecutek file
frs87 is offline   Reply With Quote
Old 04-07-2014, 01:17 AM   #31
frs87
Drives: red/black
Originally Posted by Tromatic View Post
Is the person doing the autopsy the same person who installed the turbo?
yes the person doing the autopsy is the one who installed it, he said he went by the directions, he even said i was too lean, now he thinks i should lower the compression to 9 or 10 to be on the safe side but idk if i wana do that, i been researchin that all day , people have been having good success with this kit so im just completely shocked this happened to me, smh that terrible moment riding in a tow truck looking in the mirror seeing that sexy intercooler in the front bumper but cant drive it
Old 04-07-2014, 01:31 AM   #32
frs87
Drives: red/black
it didnt blow at idle, it started knocking when i got on it
Old 04-07-2014, 01:35 AM   #33
s2d4
s2d4's Avatar
so where is the log? you said you would post it but just continued to not post it?
Old 04-07-2014, 02:09 AM   #34
Tromatic
It's still not clear if the tune you were running was an FI tune.
Old 04-07-2014, 02:13 AM   #35
nelsmar
Looks like the tune was for a 3 bar map. At idle it was 1.00 - 1.05 manifold pressure which is obivously wrong. If you take the math from atmospheric pressure from the stock map at idle and shift it you end up with 1.0-1.15 or so Bar with an omni 3 bar map sensor calibration being loaded in. But the map sensor alone shouldn't blow it up. If anything it should be adding additional fuel. Unless he was bouncing off of a boost cut, but even then most tuners typically completely disable the injectors so you wouldn't be getting a lean burn.
The log is worthless he sent it to me it is about ~5. =( Fuel trims are about right, afr is at stoich, but MAP is reading quite high.
Old 04-07-2014, 02:25 AM   #36
Crazy Drew
Drives: Smells like tires when I drive
Like... Pegged out? Beyond what the OEM MAP sensor can read? I'm only assuming at this point he was running a 1 bar MAP.
Crazy Drew is offline   Reply With Quote
Old 04-07-2014, 02:26 AM   #37
Bigmaxy
Drives: Pegasus GTS86
If you post the log it will be pretty easy to see if your fuel pressure is ok and what your afr was like during boost. Otherwise it's all speculation.
Stock internals will run 8psi (and more) easily with correct tuning, no need to drop compression ratio unless you are planning on chasing huge numbers. You could use this opportunity to build a stronger motor but you wouldn't need to drop c/r.
edit. Log was sent. posted at the same time.
Bigmaxy is offline   Reply With Quote
Old 04-07-2014, 04:43 AM   #38
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Were you getting on it with the base map only, or was it tuned before you got on it. That part is a little unclear to me. You should never get on a basemap and generally keep it out of boost until it is properly tuned.
There are a lot of ways that it could have gone bad that without taking a close look at it, it is really hard to say. You're pretty close to Dynosty though. You might want to have them check things out.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 04-07-2014, 06:08 AM   #39
mikepaul21
mikepaul21's Avatar
Drives: 2013 Subaru BRZ
I'm planning on boosting my car when I get back from this deployment, anyone know any good tuners in the NC/SC/VA area that are reliable and good tuners. I don't mind spending a lot of money on a tune I just want everything to be right.
mikepaul21 is offline   Reply With Quote
Old 04-07-2014, 07:31 AM   #40
Dipstik-sportech
Dipstik-sportech's Avatar
They guy who installed it even said it was too lean but you still went and beat on it? I still say the fuel pump install is at fault here but I'm sure the guy will say no even if it was just to save his reputation. Get the logs to LJ asap and he'll tell you what happened.
The Frozen North
Old 04-07-2014, 08:38 AM   #41
Shawnofthedead
Shawnofthedead's Avatar
Drives: Black on black with so much class
Kids go to @Crawford Performance or @Evasive Motorsports
Shawnofthedead is offline   Reply With Quote
Old 04-07-2014, 09:16 AM   #42
Lavalover
Drives: 2014 FR-S Monogram Hot Lava
In northern VA, PTuning:
http://www.ptuning.com/
Lavalover is offline   Reply With Quote
The Following 2 Users Say Thank You to Lavalover For This Useful Post:
mikepaul21 (04-07-2014), Sportsguy83 (04-10-2014)
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 10:46 AM
2013 FR-S Full Blown Motorsports Stage1 Turbo kit. Mustang Dyno results. Infamous Performance Forced Induction 10 07-03-2013 09:52 PM
FINAL RESULTS: Taking Full Blown Stage 1 To The MAX! @Pure Automotive (Dyno Inside!) Pure Automotive Forced Induction 57 03-28-2013 12:41 AM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Performance! Pure Automotive Forced Induction 181 03-12-2013 03:11 PM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Pure Automotive Mid-Atlantic 22 02-12-2013 11:13 AM
