Old 01-21-2014, 01:51 AM   #141
Vlady
Vlady's Avatar
Drives: Argento Scion FRS
Originally Posted by shiv@vishnu View Post
Here is your ecutek "stock" ROM compared to an actual stock ROM:
You can see some non-stock data where there should be FFs. This also changes the checksum data at the end of the ROM (not shown).
Until we come up with a way to flash non-stock and old ROMs to new stock ROM status, I've added your ecutek "Stock" rom to the database so it should work for you now.
soooo.....now v1.53 is released
v1.53b Changes:
-Replaced the stock A01G and A01D ROMs in the database with actual stock ROMs.
-Added a “stock” Ecutek ROM to the database.
If anyone else with one of the supported ROM types doesn't get tuned map file generation, please email me your original ROM so I can compare it to the counterpart in our map database. If they aren't 100% identical, tuned map files will not be generated. I will have to add your original ROM to the database.
Cheers
shiv
OK.. so forgive me here. What does this mean??lol
Vlady is offline   Reply With Quote
Old 01-21-2014, 03:03 AM   #142
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Great. I'll add your ROM to the database later tonight and post up a new .dev file
It's possible that the A01G in the database isn't perfectly stock. Since you are sure yours is, I'll replace it with your file.
Hi Shiv, for the preloaded OFT's being shipped out this week, how "up-to-date" are the preloaded files in there? Would it come with the latest 1.53b release?
Fizz is offline   Reply With Quote
Old 01-21-2014, 03:16 AM   #143
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Yep. We will always load the newest release before shipping OFTs.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Fizz (01-21-2014)
Old 01-21-2014, 03:45 AM   #144
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
1.53b works for me meow. Thanks Shiv
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
Shiv@Openflash (01-21-2014)
Old 01-21-2014, 06:30 AM   #145
steve99
Drives: FT86
Hi Shiv,
A01G works for me now thanks
Old 01-21-2014, 06:38 AM   #146
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Hi Shiv!
Just tried 1.53b to write, but "write" button is grey.
Will send you my original ROM shortly.
Please take a look what is wrong in my case.
Thank you in advance,
Andrey A00G.
Ondreiko is offline   Reply With Quote
Old 01-21-2014, 07:02 AM   #147
steve99
Drives: FT86
Ecutek have written extra bits of data into the "stock" rom in areas that are just padding or spare space ie ""FF".
This may be for various reasons, but likely to be so that ecutek can identify the ROM as one of theirs for licensing/locking tune ect or that Ecutek has written to this ROM/vehicle at some stage.
Ecutek can also add extra features to their ROM's (RaceROM's (not this one as its a "stock" ROM), to do this they patch the original ROM's instruction code with extra code (program instructions) to perform extra functions such a map switching. this extra code need's to be inserted in "spare" or unused spade in the ROM usually this will be filled with "FF". The extra code data for alternate maps ect is usually inserted in this unused space. These ROM's are also locked/encrypted such that an ECUTEK licence is required to access/flash the ROM's I believe not even dealers can access/flash ecutek locked ROM's
Well that the way i think it works anyway.
Vlady (01-21-2014)
Old 01-21-2014, 08:39 AM   #148
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
That's great news for me!
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 01-21-2014, 05:31 PM   #149
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Any more details as to what some of those trim/timing changes etc. are relative to 1.42b?
I'm interesting in knowing a little bit about what adjustments are made and why, for learning purposes! If you'd rather PM to keep it more private, that's okay too!
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 01-21-2014, 05:50 PM   #150
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Easiest way is to datalog and compare the results:
Stage 1 1.42b
Stage 1 1.52b
Not the same stretch of road, but more or less the same conditions and the same tank of gas.
AdrianG is offline   Reply With Quote
The Following User Says Thank You to AdrianG For This Useful Post:
enwave (01-21-2014)
Old 01-21-2014, 06:44 PM   #151
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Ondreiko View Post
Hi Shiv!
Andrey A00G.
You should be good to go now with the v1.54 download. I updated the stock A00G file with your original ROM
Cheers,
Shiv
Sargy (01-21-2014)
Old 01-22-2014, 02:44 AM   #152
moK
Drives: White BRZ
What is your ROM type/CAL ID?
OpenFlash Manager reports my CAL ID as ZA1JA00C. However, plugging in the OFT into my car and going into Tuning -> ECU Info reports my 'Calibration Code' as ZA1JA01C, while going into Information from the main menu reports 'File in ECU' as a ZA1JA00C bin. I'll send you my stock file to take a look at.
moK is offline   Reply With Quote
Old 01-22-2014, 02:47 AM   #153
Shiv@Openflash
Drives: 2013 FRS
That's totally fine. Your original ROM is indeed an ZA1JA00C. However, when updating your ROM with the new v1.5 maps, your ROM will be updated to A01C.
Old 01-22-2014, 03:05 AM   #154
moK
Drives: White BRZ
Thanks for the super quick reply. In that case, any idea why Write would still be grayed out?
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 01:29 AM
OpenFlash Tablet: OFT 3-Touch Programming with Preloaded Tune File Database Shiv@Openflash Software Tuning 154 12-12-2015 04:26 PM
OpenFlash Tablet E85 (and gasoline) Maps now available Shiv@Openflash Software Tuning 401 08-14-2014 12:14 AM
OpenFlash Tablet: new v1.40b maps, new website, new sales, oh my Shiv@Openflash Software Tuning 122 12-14-2013 11:17 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
