Old 01-02-2014, 12:36 PM   #1
Maruthas
Drives: SWP BRZ
how do i install sti front lip?
is there manual on web that i can see?
i tried to google it but with no luck.
i just dont have confidence without install manual.
thank you so much!
Maruthas is offline   Reply With Quote
Old 01-02-2014, 01:43 PM   #2
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
This is what I did. Jack the car up safely and support the car on a set of stands. Block the rear wheel and start removing the front two wheels. The nice thing about the front lip is it is almost impossible to misalign since it wraps around the bumper itself and secures to the wheel well. First things first, after removing the clips under the front bumper, yes all of them, there will be a plastic splash guard that should move around, carefully take it out of there. You will then see 3 bolts, 11mm socket should do the trick "purely going off memory of 2 months ago so may be a different size" and loosen them and take them out.
After that you will see this black plastic piece that should slide around above that beam where you removed the bolts. I left it I and wedged my hand under it and above the bottom of the bumper to make sure I could reach the area where drilling would happen. It will not be comfortable to wedge your hand in there but if you can stick it out for a little bit, makes it easy.
After that I took the lip and the large pop clips, pushed them in with the lip attached and it held it in place enough to secure it for accurate hole marking. Take a sharpie or some other marker, mark your holes, then drill a hole on one side, going from the middle out, secure with the screws provided in the order of lip, bottom of car, bumper, inside of bumper. So the sequence will be grab bolt, washer, and rubber fitting. Bolt into hole with pre positioned washer, wedge hand under black plastic piece, put larger washer over the bolt on the inside of the bumper, rubber fitting over washer with lip of the rubber fitting on top (not against the washer). Rinse and repeat. Drill holes for the wheel well after and secure. Pictures would make this easier but I was too excited to take any. You can also remove the bumper if you so wish, but that is a different set of instructions
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below.
Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty.
The Following User Says Thank You to Khazzy For This Useful Post:
Maruthas (01-02-2014)
Old 01-02-2014, 04:54 PM   #3
Maruthas
Drives: SWP BRZ
Originally Posted by Khazzy View Post
This is what I did. Jack the car up safely and support the car on a set of stands. Block the rear wheel and start removing the front two tires. The nice thing about the front lip is it is almost impossible to misalign since it wraps around the bumper itself and secures to the wheel well. First things first, after removing the clips infer the front bumper, yes all of them, there will be a plastic splash gaurd that should move around, carefully take it out of there. You will then see 3 bolts, 11mm socket should do the trick "purely going off memory of 2 months ago so may be a different size" and loosen them and take them out.
After that I took the lip and the large pop clips, pushed them in with the lip attached and it held it in place enough to secure it for accurate hole marking. Take a sharpie or some other marker, mark your holes, then drill a hole on one side, going from the middle out, secure with the screws provided in the order of bottom of car, lip, bumper, inside of bumper. So the sequence will be grab bolt, washer, and rubber fitting. Bolt into hold, wedge hand under black plastic piece, put washer over the bolt, rubber fitting over washer with lip of the rubber fitting towards the ceiling. Rinse and repeat. Drill holes for the wheel well after and secure. Pictures would make this easier but I was too excited to take any. You can also remove the bumper if you so wish, but that is a different set of instructions
Thank you i'll try this.
Old 01-02-2014, 08:32 PM   #4
Khazzy
Khazzy's Avatar
Made a few corrections, typed it on my iPad this morning when I woke up lol. If you need any help, shoot me an PM or quote me and I will reply.
Anyone install a front lip and/or side skirts? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 78 04-06-2015 06:08 PM
anybody install sti front lip? tjohnson104 Cosmetic Modification (Interior/Exterior/Lighting) 2 12-08-2013 04:14 AM
cel after front pipe install assbox Engine, Exhaust, Transmission 18 11-26-2013 03:02 PM
Strano Front Bar install blkwrxwag DIY (Do-It-Yourself) Guides 21 10-06-2013 05:26 PM
Assistance on DIY front pipe install. Osiris DIY (Do-It-Yourself) Guides 3 04-18-2013 11:31 PM
