Old 10-28-2013, 01:17 PM   #365
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by Calum View Post
All of these kits will be pretty close to the same peak output.
Not trying to cause an arguement but the turbo will have a pretty significantly higher output than the superchargers.
Old 10-28-2013, 01:18 PM   #366
Taber
Drives: 2013 BRZ Limited
HOLY SHIT!!! REALLY??!?!?!?!
Taber is offline   Reply With Quote
Old 10-28-2013, 02:35 PM   #367
gmsii
gmsii's Avatar
Originally Posted by digital_assassin View Post
Good call @ft_sjo. I'm curious about the pulley and belt routing too. Haven't seen that one yet.
@gmsii - can you get a picture with the throttle body intake tube off shooting down to expose belt routing?
here you go:
gmsii is offline   Reply With Quote
The Following 5 Users Say Thank You to gmsii For This Useful Post:
cobrabyte (10-30-2013), CSG Mike (10-28-2013), digital_assassin (10-28-2013), OjiGeorge (02-02-2014), RUNAMUK (10-28-2013)
Old 10-28-2013, 05:01 PM   #368
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Awesome. You can see right where the C38 would mount to. Thanks @gmsii!
digital_assassin is offline   Reply With Quote
Old 10-28-2013, 05:12 PM   #369
CSG David
CSG David's Avatar
I spy double-sided cog belt or are my eyes playing tricks on me? I'm curious, do the two cog gears shown have different pitch sizes?
Old 10-28-2013, 05:15 PM   #370
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
From that routing yeah it needs to be double sided.
Nolan
pheoxs is offline   Reply With Quote
Old 10-28-2013, 05:17 PM   #371
Taber
I will reserve my final judgement for when this kit has officially be released and installed on some cars, but I think this may end up being the FI kit for me once winter has ended.
Old 10-28-2013, 06:18 PM   #372
Calum
That Guy
Drives: 2013 asphalt FRS MT
Old 10-28-2013, 06:28 PM   #373
Calum
That Guy
Yup, that was my first thought. I'm REALLY curious why they didn't use two pulleys, mounted lower then the SC drive pulley, and a single sided belt. They could have maintained the same pulley coverage, and could have mounted the tensioner assembly at a 45 deg which would have made it easier to adjust while it's mounted to the car. This way, all pulleys have to be cut with a gear pattern, they have more pulleys, and a longer & more expensive belt. I'm wondering what was in the way. ???
The Following User Says Thank You to Calum For This Useful Post:
B L U E S L A T E (10-29-2013)
Old 10-28-2013, 06:44 PM   #374
nelsmar
Modern superchargers aren't as inefficient as they used to be... I made 360WHP with 11.5PSI on E85 and a full stock exhaust with stock header, both cats... I am pretty close to most of the turbo guys in my pressure range. Sure the turbo guys may be slightly better, but a lot of turbo setups have 1 or 0 cats, full exhaust, high flow header, etc. Mid range power? sure, they make more psi at a lower RPM with the downside of a higher transient lag than I have. But saying that a ton of power is lost by using a supercharger isn't fully accurate. But lets not take this thread off topic in a debate about what is better.
My flickr - Canibeat
Local magazine scout
Old 10-28-2013, 08:09 PM   #375
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
I'm not so sure the 3 pulleys need to be cut to match the cogs ...
so long as the pulleys have a bevel of some sort on the inside edge it will collect the belt and spin accordingly provided there is proper tension in the belt system ...
As for the pulley count and placement, I seem to remember a best practice of having a pulley between each cogged wheel in a machinist environment ... not sure if that applies to engine bays ... It's been years since I had that training ...
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 10-28-2013, 09:54 PM   #376
Calum
That Guy
I don't know how a cogged belt would react to the cyclical compression of the cogs caused by being under tension while running over a smooth faced pulley. My thought is that the belt wouldn't like it at all, which would either diminish the belts life, or require cogged idler pulleys.
Two pulleys would still satisfy that best practice, would it not? My thought is that there would be two pulleys on either side of the compressor, but lower instead of above the compressor pulley.
I'm not trying to argue here, I'm just trying to expand on my earlier post to ensure I wasn't misunderstood. I posted my idea expecting to be told it wouldn't work, I'm just not sure why it wouldn't work.
Old 10-28-2013, 10:18 PM   #377
Oh I'm not trying to argue either Calum ... just was cleaning some cobwebs off of some distant training I had on pulley and gear systems in production line equipment. I'm all for being 100 percent wrong and learning by my foolishness. Science and understanding require it!
The Following User Says Thank You to TrogDor the Burninator For This Useful Post:
Calum (10-29-2013)
Old 10-28-2013, 10:36 PM   #378
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
My bet is that they are using the other pulleys and the back side of the belt to spin the supercharger the opposite direction of the crank pulley due to the design of the turbine.
kask2_6.0 is offline   Reply With Quote
The Following User Says Thank You to kask2_6.0 For This Useful Post:
Calum (10-29-2013)
[TX] DFW General Discussion feedbag Southwest 1488 06-18-2022 08:25 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 04:28 PM
ROTREX SC Brainstorming MANDALAY Forced Induction 61 12-11-2012 06:57 PM
Rotrex kit - why no build? MindtheGap Engine, Exhaust, Transmission 5 10-26-2012 08:01 PM
