Old 10-03-2013, 03:01 PM   #99
Dezoris
Dezoris's Avatar
Originally Posted by ATL BRZ View Post
Don't forget that the Rotrex does so more efficiently than the Vortech. The Rotrex doesn't overheat when tracked hard like the Vortech does requiring Gem to go oil fed with his after blowing out the impeller seals IIRC. We don't have track data for our platform for either the JR or KW Rotrex kits and so all we have to go on is what other platform's have experienced.
I don't think that is accurate at all, on the stock pulley he never overheated the SC. The only issue he had was the SC oil being filled to the point of it being blown out. Which was an issue with proper oil level Vortech had to change documentation on.
Unless I am wrong
Old 10-03-2013, 03:03 PM   #100
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Unless I am wrong
You're probably right it's been a while since I read his posts about it.
I just remember him saying he was able to heat soak it to where it was noticeable with enough repeated abuse on track, even before pulley upgrades and seal failures.
It'd be a lot easier to find his posts if he didn't have like 4 usernames.
@Adeets , @Dezoris , do either of you have technical data sheets with compressor maps for the Vortech V-3 H67B used in your cars like this one?
That would make it a lot easier to compare the two SC's accurately (in a separate thread, maybe?)
Old 10-03-2013, 03:16 PM   #101
sw20kosh
Drives: 2013 Black FR-S
The rotrex is supposed to be able to produce more mid range power than the vortech design isn't it?
Old 10-03-2013, 03:31 PM   #102
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
I have never been a fan boy for Vortech. I basically publicly trashed them after my install. But they have proven themselves in terms of support and fixing issues, and reliability its the most popular SC because of it.
The problem has and always been transparency. On these forums, it's so tiring seeing 95% marketing and a sprinkle of data. When you question anything you are either a troll or made to be an idiot.
My feeling is if you peddling a product online or forums have the data to back up your claims. If you did your homework and proper testing then there should be very little to hide.
I didn't mean to pick out anybody running a vortech .
I totally agree with 95% of what you said is true but the ironic thing is while you ask for track tested data a majority of the vortech sponsored cars run a rocketbunny kit, slammed or are parked at home
Sorry sent from my phone
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
ATL BRZ (10-03-2013)
Old 10-03-2013, 03:33 PM   #103
ATL BRZ
ATL BRZ's Avatar
Exactly. There are 4, maybe 5 Vortech fitted cars that I know of here that have seen repeated track abuse. Not just a one day event in a novice run group.
I've seen quantifiable track data from three of them: Gem's, Dezoris', and F1Point4's; but Gem is the only one I've seen really beat the shit out of the car and try to break stuff. The rest are driven rather gingerly around the track IMO. No offense, it's just how run groups are structured for driver's just getting into HPDE's.
There is also SpeedFactory's and Chase Bays' Vortech'd track cars, but so far all I've seen are lots of pictures and a few video clips, no extensive uncut track footage or data.
Old 10-03-2013, 03:46 PM   #104
jamesm
this car isn't suitable for track use in stock form, not sure why anyone would expect differently with a supercharger bolted on.
Old 10-03-2013, 03:52 PM   #105
ATL BRZ
ATL BRZ's Avatar
Hopefully whomever goes FI with this car with the intention of tracking it will at least install an oil cooler, bigger radiator, and a stronger clutch as well as provision the brakes and all fluids for track usage.
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
Sonolin (10-03-2013), Turbowned (10-07-2013)
Old 10-03-2013, 04:25 PM   #106
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
My main issue with this kit and the JR kit is the aesthetics. The vortech SC is the nicest looking, just like the AVO kit is the nicest looking turbo.
For a lot of people, that matters
The Following User Says Thank You to SkAsphalt For This Useful Post:
Old 10-03-2013, 05:41 PM   #107
Calum
That Guy
Drives: 2013 asphalt FRS MT
We all have our priorities. No one can fault you for yours.
The Following User Says Thank You to Calum For This Useful Post:
SkAsphalt (10-03-2013)
Old 10-03-2013, 06:02 PM   #108
Dezoris
Dezoris's Avatar
I can't find the image but Vortech posted it a long time ago. @Brian@Vortech @Rick@vortech can you guys link or repost your compressor map?
Old 10-03-2013, 06:08 PM   #109
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
I will wait to see the results form this kit. I remember Swift Racing Tech (the guys who made a great exhaust and then f*** up by not building them fast enough) was going to develop a SC for the twins. I think they said twin screw or something, that was clutched so it could disengage when cruising.
I am excited JR and Krafwerks are working on rotrex sollutions, by next year I will be going FI and I will have a lot of choices to make - which is great
Old 10-03-2013, 10:08 PM   #110
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
That has always been the assumption. Clever wording from Rotrex coupled with internet forum jockeys piecing together assumptions from what they read resulted in people thinking that a Rotrex unit would have a better boost curve than every other centrifugal supercharger on the planet, which would give you better low end torque.
It's never been proven, to my knowledge.
Sellout is offline   Reply With Quote
Old 10-04-2013, 03:55 AM   #111
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
I just bit. I'm #21 it looks like. One of the selling points for me is it doesn't share the same belt. Rotrex and Kraftwerks are pretty solid so I guess it's time to be an early adopter! Time to start looking for headers...
@Drift-Office - You down to do a tune on this Bob? I currently have EcuTek. Ready to start talking with you about best options for this track build.
digital_assassin is offline   Reply With Quote
Old 10-04-2013, 01:43 PM   #112
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
I found it on google images under "BRZ vortech flow graph" but I'm on my phone so can't link it, I did notice max rpm on the rotrex 94 was 100k, but looked like they did data up to 250k
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
[TX] DFW General Discussion feedbag Southwest 1488 06-18-2022 08:25 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 04:28 PM
ROTREX SC Brainstorming MANDALAY Forced Induction 61 12-11-2012 06:57 PM
Rotrex kit - why no build? MindtheGap Engine, Exhaust, Transmission 5 10-26-2012 08:01 PM
