Old 09-07-2013, 09:11 AM   #85
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Originally Posted by mad_sb View Post
I will provide updated weight for the FA20 equal length main section and catless down-pipe section next weekend hopefully.
Pikchas!
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 09-07-2013, 09:19 AM   #86
diss7
Drives: AE86, 2x GT86, TE27
Talked to my fabricator re OD and ID.
He said most people reference exhaust as OD.
Confusing, as he said tubing is generally OD, piping is generally ID. With that in mind, exhausts should be called exhaust tube.
Not satisfied, I pushed the issue further, because would you then not have to consider wall thickness to find out actual ID. If its typically OD, then as an example a full Tomei system that is specified as 60mm, would not line up as the headers and overpipe are stainless, and the rest is titanium. Titanium walls would be thinner. So IDs would be different. He believes that in that particular example, Tomei are a manufacturer that would quote ID.
Still talking about Tomei. They state 60mm. Now lets assume that is ID. Comparing that to another system that is listed as 2.5", which is larger than 60mm, might have an ID smaller than the Tomei unit, depending on wall thickness.
I think we need more members/vendors to get out their verniers. One for more accurate information, but also because you may be mixing and matching 2.5" components from different manufacturers that's arent the same ID.
diss7 is offline   Reply With Quote
Old 09-07-2013, 09:42 AM   #87
Anthony
Weight Nazi
Anthony's Avatar
Haha yep, I've pretty much had all of these same thoughts and feelings. I wish I could go to a few of the big vendors and be let loose with a bunch of measuring devices.
Old 09-07-2013, 06:20 PM   #88
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
@Anthony Tsudo Overpipe Exhuast, as weighed by SEmotors. Tsudo midpipe and catback aren't listed in first post yet.
41.55 lbs = Frontpipe-back Exhaust
7.6 lbs = Frontpipe (Catted)
33.95 lbs = Catback
21.6 lbs = Axleback
12.35 lbs = Midpipe
Sources:
41.55 lbs
http://www.ft86club.com/forums/showp...8&postcount=20
41.40 lbs
http://www.ft86club.com/forums/showp...05&postcount=2
mwjcyber is offline   Reply With Quote
Old 09-07-2013, 11:44 PM   #89
Anthony
Weight Nazi
Anthony's Avatar
Thanks. Updated.
There are some small discrepencies there in tenths of pounds. Like I already have the front pipe listed as 7.8, but you've got 7.6. I would say I'd go with the first to provide a photo of the weight on a scale, but different scales are going to read differently at those increments. And I assume most people don't care about a 0.2 pound discrepency in their exhaust anyway.
I would, if two were tied. I'd want the lighter of the two, but I'm kind of crazy.
Old 09-16-2013, 09:14 AM   #90
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Just saw this posted 40 mins ago, made in the UK http://lightweightperformancetitaniu...roducts_id=158
Build Thread
Instagram
Old 09-16-2013, 09:48 AM   #91
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
JDL coated headers are 13 pounds according to my scale.
industrial is offline   Reply With Quote
Old 09-18-2013, 06:42 AM   #92
Anthony
Weight Nazi
Anthony's Avatar
Thank you, sir. Updated.
I first saw your post at work a few days ago. The pictures weren't loading on that site, so I meant to look at it on my own computer later. But I forgot. Now I'm back at work and felt like updating the list, but I still can't see any photos. Is there a specific brand name for this thing? I just used its model name in the list. I'll try to remember to look at the site again later. This is what I'm seeing now:
Old 09-18-2013, 07:13 AM   #93
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
I should probably point out that the "TO-YO-07" looks almost exactly the same as the one you have in the list called "This Thing".
neurokinetik is offline   Reply With Quote
Old 09-18-2013, 07:24 AM   #94
midnight23
build is very similar but the burn points are different.
Build Thread
Instagram
Old 09-18-2013, 07:26 AM   #95
Anthony
Weight Nazi
Anthony's Avatar
Haha "this thing." Yeah, I can't see the pictures to compare. It could be the same one. It seems like it's made in the UK though, and the This Thing is made in Japan. I haven't looked that much into either one though.
Old 09-18-2013, 07:28 AM   #96
midnight23
This site is a sub company of garage whifblitz to my knowledge, they do high end supra and gtr parts. But make and sell all of their titanium exhausts on that site. I have no issues loading the site on my end, might be your browser
http://www.garagewhifbitz.co.uk/
http://www.garagewhifbitz.co.uk/inde...aust-3749.html
^ found listing on their site
Build Thread
Instagram
Old 09-18-2013, 07:35 AM   #97
Anthony
Weight Nazi
Anthony's Avatar
I have no issues loading the site on my end, might be your browser...
Work computer. 90% of the internet is blocked.
Old 09-18-2013, 07:51 AM   #98
midnight23
joys of working for an ISP, all of the internet has to be available for "testing" purposes ;]
Build Thread
Instagram
Borla UEL headers + HKS Front pipe + Greddy SP AxleBack = music sounds to my ears. NoFear99 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 09-22-2013 11:02 PM
FS: OEM Exhaust and Mid and front pipe Bcarlos Engine, Exhaust, Bolt-Ons 3 07-24-2013 05:16 PM
Exhaust,test pipe, over pipe, headers, or suspension build ShikoBariki Engine, Exhaust, Transmission 20 05-01-2013 04:16 PM
P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? Xdragonxb0i Engine, Exhaust, Transmission 23 04-24-2013 12:29 PM
