Old 02-04-2013, 12:41 PM   #141
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by dwx View Post
That's just a low pressure switch which lights the oil pressure light on the dash. The BRZ has no stock oil pressure sensor. Same with pretty much all other Subarus they have the oil temp sensor but just a low pressure oil switch.
You'll have to add an aftermarket sensor/gauge. Also unless there is some kind of bad failure, you can use the oil temp to gauge pressure pretty well.
There isn't really any big need for a pressure sensor, but the switch is definitely necessary. And now the temp would help out boosted people such as myself quite a bit.
Old 02-04-2013, 03:04 PM   #142
xwd
The switch is useless for the most part, it goes off at such a low pressure the engine is would be toast by the time it actually lit, if you are driving it hard.
I've always installed a pressure gauge in my turbo Subarus.
Old 02-04-2013, 06:42 PM   #143
lazyluka
Drives: GT86
Originally Posted by andreyiv View Post
Hey guys,
I found the Oil Temperature PID using TorqueScan and verified it by driving, as well as heating up only the oil temperature sensor area with the engine cold (and not running).
Without further delay, here's the info:
OBD2 Mode and PID: 2101
Minimum Value: -40
Maximum Value: 215 (this is just the maximum that this location can support, which does not mean the sensor can read that high)
Scale factor: x1
Unit type: C
Equation: AC-40 (no space between A and C; "AC" is the location within the response)
OBD Header: 7E0 (Auto also works, but seems to take longer)
Just as an aside, I don't know if it's my OBD adapter, or the Header needs to be tweaked (corrected), or if the response is not always long enough but every once in a while I'll get a reading of 189 or 1840 which are both incorrect. I'm not familiar enough with torque to figure out where these glitches are coming from.
Enjoy!
Andrey
Thanks!!! You saved most of us a huge amount of money!
Originally Posted by Brody602 View Post
I will be adding this to the first page, sorry for the delay I have been busy, thanks a lot for your hard work and contribution!
Brody
When you update the first post perhaps we should try get an admin to sticky this under the DIY section or something as this is really useful.
lazyluka is offline   Reply With Quote
Old 02-04-2013, 07:07 PM   #144
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
I've already updated it, onto the second post which will be strictly for pids, i have put in my OP a request for sticky, but I might contact an admin
Agreed, extremely useful and cheap alternative way to monitor the engine etc, which is the reason why I originally made the thread
Can't give enough credit to andreyiv for his hard work. Also to Yruyur for his reverse engineering ideas, if it wasn't for Yruyur's issues with his phone he probably would have beat andreyiv to it, but none the less hard work has paid off and hopefully we can reverse engineer more useful PID's
Cheers,
Brody
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
The Following User Says Thank You to Brody602 For This Useful Post:
Yruyur (02-04-2013)
Old 02-04-2013, 07:32 PM   #145
Yruyur
Yruyur's Avatar
So which one do we want next?
Old 02-04-2013, 07:45 PM   #146
Brody602
Drift King
Brody602's Avatar
Well, as you may already know, I still don't have an FR-S , should have mine at the end of April/May sometime. What other sensors do we have that are recorded but we don't have access to in Torque? I think I remember someone asking about monitoring the TPMS? Not sure :P
It'd be nice if we can get oil pressure, but it seems what we thought was a pressure sensor is simply a switch to indicate low pressure
I'm keeping score so far for PIDS :P,
Toyota: 0
FT86Club: 1 :happy0180:
Also has any checked on a BRZ to see if the PID is the same as the FR-S/GT86?
Brody
Old 02-04-2013, 08:03 PM   #147
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Originally Posted by arghx7 View Post
The engine has no oil temperature sensor. If this is really oil temperature you are reading, it is only an estimate, most likely used for AVCS control. We don't know how good that estimate is.
Incorrect - it has OEM oil temp sensor
nzer is offline   Reply With Quote
The Following User Says Thank You to nzer For This Useful Post:
Brody602 (02-04-2013)
Old 02-04-2013, 08:06 PM   #148
Brody602
Drift King
Brody602's Avatar
I have contacted ichitaka05 in regards to have this thread stickied, his reponse was that he would have to discuss with the fellow moderators and if they deem it worthy it will be stickied. Let's hope for a sticky, the more views we get the more possibility of having addinitional members help reverse engineer other PID's.
Cheers,
Brody
The Following 2 Users Say Thank You to Brody602 For This Useful Post:
SkAsphalt (04-27-2014), whataboutbob (07-20-2013)
Old 02-04-2013, 09:08 PM   #149
keen as
keen as's Avatar
Drives: 86 GT MT
Great thread. And thanks andreyiv!!!!
keen as is offline   Reply With Quote
Old 02-04-2013, 10:23 PM   #150
telamon
telamon's Avatar
Drives: CBS BRZ
Works great with my BRZ, big thanks to andreyiv :happy0180:
Here's a link to the results of a full PID scan I did the other day: http://pastebin.com/D1gkE1f5
telamon is offline   Reply With Quote
The Following 2 Users Say Thank You to telamon For This Useful Post:
Brody602 (02-04-2013), whataboutbob (01-01-2020)
Old 02-05-2013, 02:00 AM   #151
Kamran
Pepe Le Pew Wannabe
Kamran's Avatar
Has any one looked into the iPhone version app, called: Engine Link - OBD II?
Would the inputs/instruction listed here for the oil temp output be identical for the iPhone app?
Any exerience...?
My middle age crisis started prematurely… at 16!
I'm also independently very, very..... dependent!
Kamran is offline   Reply With Quote
Old 02-05-2013, 02:51 AM   #152
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Any exerience...?
Anything OBD-II PID will work with anything OBD-II PID, so yes.
Of course, if only the Engine Link app lets you customize your own PID. Which they should..
LeeMaster is offline   Reply With Quote
The Following User Says Thank You to LeeMaster For This Useful Post:
Kamran (02-05-2013)
Old 02-05-2013, 03:41 AM   #153
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Can anyone list a good obd sensor that they are using.
Sent from my HTC6435LVW using Tapatalk 2
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 02-05-2013, 05:22 AM   #154
LeeMaster
Red wine
ELM327 is what im using, got it from ebay for $9. Make sure whatever device you are using supports blueray.
Speaking of sticky this thread, I think the moderators should instead create a new DIY/how to thread of their own and list shortcut links for everything useful that comes up. This way we wont get too much sticky clutter in the near future and everything we need is just a click away.
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 05:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-23-2012 12:05 AM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 05:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 02:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 09:23 PM
