Old 02-03-2013, 10:45 PM   #127
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Sweet. Going to give it a try tonight
Sent from my DROID RAZR using Tapatalk 2
Area86 is offline   Reply With Quote
Old 02-03-2013, 10:55 PM   #128
jpit
Drives: Subaru BRZ
If you change the unit value to F will it read in fahrenheit? Thanks.
jpit is offline   Reply With Quote
Old 02-03-2013, 10:59 PM   #129
jpit
Drives: Subaru BRZ
I guess if 215 is the highest value F wouldn't make much sense. Also, is the OBD Header Seven E Zero?
Old 02-03-2013, 10:59 PM   #130
arghx7
Drives: car
The engine has no oil temperature sensor. If this is really oil temperature you are reading, it is only an estimate, most likely used for AVCS control. We don't know how good that estimate is.
Old 02-03-2013, 11:14 PM   #131
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
All the other temperatures are provided in Celsius from the ECU, so the oil temp is probably the same. (I know, it's like this car's not even from 'merkia!)
OBD Header is Seven E Zero.
Old 02-03-2013, 11:24 PM   #132
andreyiv
Drives: Hot Lava FR-S
Thankfully it does. :-) It's the sensor with a two wire plug under the oil filter. You can confirm that by unplugging it and reading the OBDII error code. The code will report an error with the oil temperature sensor.
You can also read the sensor value with the information I provided and heat up the area where the oil sensor is located (sensor with a two wire plug under the oil filter). A zip lock bag of hot water on a cold engine (not running of course) works well. You can even monitor coolant and oil as you are doing this and see the values start out the same (provided the car sat for a long time) and the oil will start very slowly climbing as you hold the sealed bag of hot water to the sensor area. :-)
Andrey
andreyiv is offline   Reply With Quote
The Following 2 Users Say Thank You to andreyiv For This Useful Post:
b.e (02-06-2013), keelerad (02-06-2013)
Old 02-03-2013, 11:36 PM   #133
jpit
Drives: Subaru BRZ
When you set up the Torque App I think it gives you a choice between celsius and fahrenfeit
Old 02-04-2013, 12:26 AM   #134
Yruyur
Yruyur's Avatar
Now we need oil pressure I think thats the other plug.
Old 02-04-2013, 12:35 AM   #135
Yruyur
Yruyur's Avatar
Works like a charm just entered all the values in. I think juat by changing the equation and mode it will read in f instead of c.
Old 02-04-2013, 12:53 AM   #136
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Buying a nexus 7 tomorrow and going to use the DIY tutorial on here to install it, always wanted to do this but never had the reason to until now.
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
The Following User Says Thank You to WolfsFang For This Useful Post:
Yruyur (02-04-2013)
Old 02-04-2013, 01:16 AM   #137
Yruyur
Yruyur's Avatar
Should install the free track recorder plug. Lets you record video with all the car metrics overlayed over the video. Walkthrough with video would be sweet.
Old 02-04-2013, 08:35 AM   #138
andreyiv
To change the read out to F, go to Settings -> Units on the main screen for Torque and uncheck the checkmark that says something along the lines of Display In Celsius. All temperature readouts I've tried (including this oil temp. readout) changed to F correctly.
Andrey
The Following 3 Users Say Thank You to andreyiv For This Useful Post:
IBill4You (06-06-2015), LeeMaster (02-05-2013), Ninjin (02-05-2013)
Old 02-04-2013, 09:15 AM   #139
Brody602
Drift King
Brody602's Avatar
Drives: '13 Firestorm FR-S 6MT
Originally Posted by andreyiv View Post
Hey guys,
I found the Oil Temperature PID using TorqueScan and verified it by driving, as well as heating up only the oil temperature sensor area with the engine cold (and not running).
Without further delay, here's the info:
OBD2 Mode and PID: 2101
Minimum Value: -40
Maximum Value: 215 (this is just the maximum that this location can support, which does not mean the sensor can read that high)
Scale factor: x1
Unit type: C
Equation: AC-40 (no space between A and C; "AC" is the location within the response)
OBD Header: 7E0 (Auto also works, but seems to take longer)
Just as an aside, I don't know if it's my OBD adapter, or the Header needs to be tweaked (corrected), or if the response is not always long enough but every once in a while I'll get a reading of 189 or 1840 which are both incorrect. I'm not familiar enough with torque to figure out where these glitches are coming from.
Enjoy!
Andrey
I will be adding this to the first page, sorry for the delay I have been busy, thanks a lot for your hard work and contribution!
Brody
'13 6MT Firestorm FR-S
Brody602 is offline   Reply With Quote
Old 02-04-2013, 10:21 AM   #140
xwd
That's just a low pressure switch which lights the oil pressure light on the dash. The BRZ has no stock oil pressure sensor. Same with pretty much all other Subarus they have the oil temp sensor but just a low pressure oil switch.
You'll have to add an aftermarket sensor/gauge. Also unless there is some kind of bad failure, you can use the oil temp to gauge pressure pretty well.
The Following 2 Users Say Thank You to xwd For This Useful Post:
Synack (02-04-2013), Yruyur (02-04-2013)
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 05:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-23-2012 12:05 AM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 05:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 02:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 09:23 PM
