Drives: 2013 GT86
Which SC kit is easiest to install?
With so many supercharger kits available I wondered what the opinion was regarding installation differences / simplicity. With the exception of the Phantom for obvious reasons.
I'm not a noddy and have worked on lots of cars before. But my car is a DD and it's not used for track work so this isn't about which is best. I just want some relatively pain free FI to make the car more exciting and it would be good to factor this in with the kit decision. Cheers (I realise most people probably choose a kit and have stuck with it, so probably not many people know what it's like installing other kits) |
#2 |
/scion
Drives: '13 86 M/T
@tzbang You should probably look into the more reliable kit, rather than easiest to install. That's of course if you don't care about "which is best." Because if you don't want a kit that is the best (by this I assume you mean performs the best) and you didn't mention reliability, why do you want a supercharged car? Because it was easy to install?
Edit: Reread your OP and notice that you want a more exciting car. |
| The Following User Says Thank You to LOLS2K For This Useful Post: | chaoskaze (11-09-2015) |
#3 |
Drives: WRB Limited BRZ
From what I been reading it's been between Jackson and Edelbrock, both just HAPPEN to be one of the most reliable ones as well.
#4 |
Drives: 2013 GT86
You are right.. reliability is important, I figured at the lower end of the scale with modest boost keeping the OEM fuelling, drivetrain etc reliability between the kits would be fairly similar.. but it's a good point, I could be wrong here! Maybe some of those kits aren't very good?
Previous I've found 'unreliability' creeps into other components when making big power gains (clutch, gears, heat issues etc). |
#5 |
Drives: '13 BRZ | '04 E55
My opinion is that the Edelbrock is the way to go. This was the kit I went with, but I have also installed:
-Cosworth Kit -Vortech Kit -Ptuning Kit -JDL Kit -SBD Kit -AVO Kit -FBM Kit The installation instructions, the packaging, the part labeling, etc in the Edelbrock kit are bar none. Not a single other kit I have installed went on as effortlessly. It was extremely well documented and there was no "modify this or that" to make it fit. Everything once installed is easily accesible. Maintenance in all areas is not hindered by the added parts. Etc. I guess it just depends on your end goals, and if it makes enough power for your liking. |
| The Following 3 Users Say Thank You to NotSoJDM For This Useful Post: |
#6 | |
/scion
Drives: '13 86 M/T
#7 |
Drives: 2013 GT86
Thanks mate that's brilliant that you've had experience with all those other kits.
I'm after 230 - 250 rwhp in a reliable package. At the moment I think fuelling could be a problem since where I live the best fuel is 95Ron (US91) sometimes we can get 98Ron which is more like your 93. No E85 where I live. :-( |
#8 | |
#9 |
Drives: 2014 BRZ SCCA STU endurance car
You only have to install it once. I would recommend picking a kit that suits your price/power/reliability goals in the long term rather than one that saves you a few hours on install.
| The Following 4 Users Say Thank You to Gear_One_Performance For This Useful Post: |
#10 | |
Drives: 2013 GT86
In terms of power I want something that gives the best punch lower in the rev range for street driving. Top speed / biggest power isn't important. |
#11 |
ELECTRIC
| The Following User Says Thank You to raven1231 For This Useful Post: | DAEMANO (11-09-2015) |
#12 |
Drives: 2013 GT86
Not entirely opposed to the idea.. only the waiting time.. I pm'd Rob and Fenton weeks ago and no response that I'm even on the wait list.
#13 |
The Jackson is a little bit less "technical", but has more steps than the Edelbrock.
Ease of installation and reliability is a virtual wash between the two. Even the output is similar, with the edge going to one kit or the other, depending on where you want your power advantage to be. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | wparsons (11-10-2015) |
#14 | |
Drives: '13 FRS - STX
Wouldn't mind to be proven wrong though, one of the 4 will likely get my money in ~4-5 years. |
| LCA install | WallsAndFoundations | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 12-16-2014 05:47 AM |
| Easiest oil change | tzhu07 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 51 | 04-18-2014 10:27 AM |
| easiest color to keep looking clean? | fatoni | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 25 | 10-10-2013 07:21 PM |
| Easiest way to get to the over-pipe? Doing an install... | seven | Engine, Exhaust, Transmission | 7 | 02-03-2013 07:38 AM |
| Colors easiest to keep clean yet looks good | fitcious | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 01-16-2013 02:22 PM |
