Old 04-26-2015, 04:46 PM   #1
Jolt182
Jolt182's Avatar
Drives: Asphalt FRS
Question about wheel/tire fittment
So im new to the mod scene. Just got my Scion Frs. Im going to be lowering the car on coilovers and getting new wheels and tires. The wheels are 18x9.5 +40 Gram Light 57Xtreme. Anybody know what size tire I should run in oder to make these fit in the front and rear? Im sure ill need some negative camber but just want to make sure I buy the right stuff!
Jolt182 is offline   Reply With Quote
Old 04-26-2015, 04:52 PM   #2
Kwise1
Kwise1's Avatar
Drives: Raven FRS
Kwise1 is offline   Reply With Quote
Old 04-26-2015, 05:00 PM   #3
Jolt182
Jolt182's Avatar
Drives: Asphalt FRS
225 in the rear as well? Just curious but wont 225 be quite a stretch on those wheels or not a big deal?
Old 04-26-2015, 06:34 PM   #4
ryoma
ryoma's Avatar
I would say go for 245 for 9.5" wheels. 9.5" is 241mm so 245 would be a good fit. you will most likely need to roll your fenders too. I'm not a fan of stretched tires and rather like the meaty look
Old 04-26-2015, 09:41 PM   #5
Jolt182
Jolt182's Avatar
Drives: Asphalt FRS
You think instead of rolling the fenders a slight amount of negative camber would do the trick? Maybe something like -2?
Old 04-26-2015, 11:06 PM   #6
ryoma
ryoma's Avatar
I haven't ran 18" wheels so I don't know. it will depend on how thick your side wall is on your tires and on how low you go. check the wheel fitment sticky in this subforum to find others who have logged their experiences with the same wheel size as yours.
The Following User Says Thank You to ryoma For This Useful Post:
Jolt182 (04-27-2015)
Old 04-26-2015, 11:43 PM   #7
Vten
Drives: Too heavy
I think I responded to your post on my wheel thread , but yeah it really depend on what are you aiming for . If you're into stretching and cambers, 215/40 can be used too ..I'm using 225/40 on my 9.5" wheels with a +25 offset.
If you search on the wheel directory , with your similar specs wheels , ppl use 255/35 or 265/35s which is a great setup if you're into more grippy setup .
Vten is offline   Reply With Quote
The Following User Says Thank You to Vten For This Useful Post:
Old 04-27-2015, 01:51 AM   #8
Jolt182
Jolt182's Avatar
Drives: Asphalt FRS
Id prefer to run as little stretch and camber as possible. The car will probably get lowered an inch or so and I just want to make sure I get tires that will fit without rub. Im not opposed to Stretch or Camber, just prefer to keep it to a minimum and have no worries about rub or other fitment issues even though the offset will be +40.
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 11:27 PM
Tire question poptopclk Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 05-07-2014 11:24 AM
Enkei T6S wheel and tire fitment question chenshuo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-30-2014 10:25 PM
tire question bkblitzed Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-16-2013 04:35 AM
Fittment question digital_assassin Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-09-2012 01:21 AM
