Old 05-16-2018, 02:07 PM   #1
razahuss
Magnetic Drain Plugs come stock for Transmission/Differential?
Do our cars come stock with magnetic drain plugs for fill/drain for the trans & diff? If not I was going to purchase some (total of 4).
razahuss is offline   Reply With Quote
Old 05-16-2018, 02:31 PM   #2
I understand that these cars come with magnetic drain plugs.
Old 05-16-2018, 05:19 PM   #3
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Yes. There are magnets on the drain plugs of both the trans/diff. It's a fairly regular occurrence for people to freak out when they do their first oil change and discover the glob of metal shavings stuck to it, and post in a panic asking if their car is about to explode.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 05-16-2018, 08:53 PM   #4
razahuss
Lol I’ve seen photos. This is my second 86 but this time around doing all the maintenance myself so just wanted to be thorough.
Thank you though!
Old 06-26-2018, 08:09 PM   #5
Whoodoo
Drives: '15 BRZ, Vortech supercharger
This was the diff and trans drain plugs at 30k (just removed and then after they were cleaned) . The diff plug has a longer magnet that sticks out, while the trans plug magnet is recessed a bit. I wish I could removed the goop and kept it in a vial because it was really fun to play with.
Whoodoo is offline   Reply With Quote
Old 06-26-2018, 09:36 PM   #6
Good pictures.
Looks like the magnetic part of the plugs were doing their job.
Old 07-02-2018, 02:35 PM   #7
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Basically the same stuff inside high dollar magnetorheological shocks.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 07-02-2018, 04:13 PM   #8
Imrac
Drives: 13 SWP BRZ Prem
So that is how they make that stuff... One transmission or Diff oil change at a time.
No wonder it is so expensive.... /s
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 07-03-2018, 08:42 AM   #9
venturaII
venturaII's Avatar
Or save it and make your own.
Manual Transmission + Differential Drain Bolt Crush Washers skylinekin Transmission and Driveline 0 12-27-2017 04:22 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
Best magnetic drain plug? FR-Sizzle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 09-28-2015 01:07 PM
Does BRZ come stock w/ magnetic drain plugs (diff/tranny)? Daedex Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 10-05-2014 08:50 PM
Transmission fill and drain plugs goshem Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 07-27-2014 12:37 AM
