-   Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) (https://www.ft86club.com/forums/forumdisplay.php?f=41)
-   -   Magnetic Drain Plugs come stock for Transmission/Differential? (https://www.ft86club.com/forums/showthread.php?t=127687)
razahuss 05-16-2018 02:07 PM
Do our cars come stock with magnetic drain plugs for fill/drain for the trans & diff? If not I was going to purchase some (total of 4).
humfrz 05-16-2018 02:31 PM
I understand that these cars come with magnetic drain plugs.
humfrz
Stang70Fastback 05-16-2018 05:19 PM
Yes. There are magnets on the drain plugs of both the trans/diff. It's a fairly regular occurrence for people to freak out when they do their first oil change and discover the glob of metal shavings stuck to it, and post in a panic asking if their car is about to explode.
razahuss 05-16-2018 08:53 PM
Lol I’ve seen photos. This is my second 86 but this time around doing all the maintenance myself so just wanted to be thorough.
Thank you though!
Whoodoo 06-26-2018 08:09 PM
5 Attachment(s)
This was the diff and trans drain plugs at 30k (just removed and then after they were cleaned) . The diff plug has a longer magnet that sticks out, while the trans plug magnet is recessed a bit. I wish I could removed the goop and kept it in a vial because it was really fun to play with.
humfrz 06-26-2018 09:36 PM
Good pictures.
Looks like the magnetic part of the plugs were doing their job.
:thumbsup:
humfrz
venturaII 07-02-2018 02:35 PM
Basically the same stuff inside high dollar magnetorheological shocks.
Imrac 07-02-2018 04:13 PM
So that is how they make that stuff... One transmission or Diff oil change at a time.
No wonder it is so expensive.... /s
venturaII 07-03-2018 08:42 AM
Or save it and make your own.
