Drives: subaru
Suspension clunking (i think)
Been having a weird issue with the car. I think its suspention related
From a stand still if i rev to about 3.5-4k and let the clutch slip i can hear knocking in the rear (barely any if any wheel spin). It certainly does not feel like tire hop but maybe it is? The sound goes away once the car is going over 25km/h. I can re perform the sound everytime from a stop Not sure if anyones had any similar issues. Thinking it could be axles maybe Im on cheap coilovers (bc racing), 265 tires with supercharger if that helps |
#2 |
If you were making a turn, I would suspect a rear axle.
But, going straight ahead, I would suspect a drive shaft universal or a bad acting differential. You may wish to check that your coil overs are bolted down tight. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | BRZ'13 (09-20-2016) |
#3 | |
I think OP has a failed CV joint.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (09-20-2016) |
#4 |
Drives: 2013 Pearl White 6MT
I had similar issues and I could feel the clunk too. After investigating; the damn seats were lose from the latch. LOL I know, the obvious right
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I
at night and ate at sun rise |
| The Following User Says Thank You to RichardsFRS For This Useful Post: | BRZ'13 (09-20-2016) |
#5 |
You say "on cheap coilovers" but not if you have done the other supporting mods. LCAs or anything else?
| The Following User Says Thank You to Tcoat For This Useful Post: | BRZ'13 (09-20-2016) |
#6 |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (09-20-2016) |
#7 | |
| The Following User Says Thank You to RichardsFRS For This Useful Post: | Ultramaroon (09-20-2016) |
#8 | |
Senior Misanthrope
#9 |
#10 |
Drives: subaru
yeah this. if i set off normally, i cant hear it. il try and film it and see if i can get it on tape. only happens on low speeds
#11 | |
Drives: subaru
i cant see it being the coils since its only at low speeds. maybe contributing to the cause? |
#12 |
Drives: subaru
#13 | |
It could also be as simple as needing to tighten the retaining nuts though. I would start with that since you certainly fit the description. Axle issues - http://www.ft86club.com/forums/showthread.php?t=49511 Nut tightening - http://www.ft86club.com/forums/showthread.php?t=92971
#14 | |
Drives: subaru
Thank you! |
| The Following User Says Thank You to BRZ'13 For This Useful Post: | Tcoat (09-20-2016) |
| Rear suspension clunking noise. Help ): | dito | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 38 | 09-15-2016 04:09 AM |
| Loud clunking underneath driver's side area: suspension, chassis, or wheel related? | loading_please_wait | Issues | Warranty | Recalls / TSB | 4 | 06-18-2015 04:13 PM |
| Clunking in rear suspension | toeout | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 01-21-2015 05:11 PM |
| Clunking sound coming from suspension | Maverickgear | Issues | Warranty | Recalls / TSB | 9 | 07-11-2014 03:41 PM |
| rear rattling/clunking suspension noise | ceebo | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 04-25-2014 11:00 PM |
