Old 07-28-2022, 09:39 PM   #1
sterling
Drives: 2018 brz auto
p0700 code and car won’t start
2018 Brz automatic. Check engine light came on. I stopped and turned engine off. Would not restart. The code was a P0700. After I cleared the code, the car started. Drove 50 miles and the code did not return. Any ideas?
sterling is offline   Reply With Quote
The Following User Says Thank You to sterling For This Useful Post:
humfrz (04-14-2023)
Old 08-04-2022, 02:12 AM   #2
CB750F
CB750F's Avatar
Drives: 2015 BRZ WRB
No idea but google is your friend.
"P0700 Subaru
The TCM monitors the sensors and actuators relating to transmission control and communicates with the Engine Control Module (ECM) to inform it of any possible issues with the automatic transmission control module. The trouble code P0700 is set whenever the TCM detects a malfunction with the transmission controls.Mar 15, 2022"
CB750F is offline   Reply With Quote
Old 04-05-2023, 12:12 AM   #3
rvoll
Drives: 2018 BRZ Limited, 2017 Sportage
I also have a 2018 BRZ auto and just had the same code when I got a smog check. Last smog check was fine without any codes or changes to the car. Also received codes U0076 and U0122. Car operates just fine in my case. I'm having Subaru check it out. My car only has 7000 miles on it... I did search the codes. It could be as simple as an indicator light or as complicated as a problem with the transmission control module. I don't have the equipment to diagnose the problem.
rvoll is offline   Reply With Quote
Old 04-14-2023, 01:08 AM   #4
Most likely just a hiccup, I wouldn't worry about it unless it returns.
Old 04-23-2023, 03:07 PM   #5
rvoll
They cleared the codes on mine and all was fine. It took driving it about 60 miles for all the code history to clear. They could find nothing wrong. The tech indicated he had seen this happen before and thought it might be a weak battery issue -- this is the original battery on a 2018 car with only 7200 miles on it.
The Following User Says Thank You to rvoll For This Useful Post:
Spairo (04-23-2023)
P0700 and U0100 Spacepeanut34 Software Tuning 6 01-16-2025 02:03 AM
P0700 CODE AFTER OFT TUNE (AT TRANS) xcuz31 Software Tuning 12 12-10-2019 06:36 PM
CEL Code P0700 and P2757 Soloside Engine, Exhaust, Transmission 5 01-27-2017 10:42 AM
P0700 Code after reading ecu with OFT FRSBRZGT86FAN Software Tuning 2 05-28-2015 02:43 PM
code P1604 possible fix? (start ability malfunction) tjsmooth25 Scion FR-S / Toyota 86 GT86 General Forum 7 06-25-2014 06:39 PM
