Old 06-21-2014, 10:46 AM   #1
tjsmooth25
tjsmooth25's Avatar
Drives: red/black
code P1604 possible fix? (start ability malfunction)
Car has been down for about a month, car struggles to turn over , stays on for two seconds with a very rough idle then shuts off, cleared the code and reflashed it with my ecutek system and the basemap reflash tune was from LJ, please help
tjsmooth25 is offline   Reply With Quote
Old 06-21-2014, 10:56 AM   #2
Dezoris
Dezoris's Avatar
What do you have done to your car?
Old 06-21-2014, 11:15 AM   #3
s2d4
s2d4's Avatar
How much fuel do you have?
Old 06-21-2014, 12:04 PM   #4
Dezoris
Dezoris's Avatar
Did you use hot dog water injection?
The Following User Says Thank You to Dezoris For This Useful Post:
extrashaky (06-21-2014)
Old 06-25-2014, 12:44 PM   #5
tjsmooth25
tjsmooth25's Avatar
Drives: red/black
Base turbo kit, 7psi , straight piped to the muffler, wideband and boost gauge
Old 06-25-2014, 12:46 PM   #6
tjsmooth25
tjsmooth25's Avatar
Drives: red/black
I have a little bit above half tank and no water injection
Old 06-25-2014, 04:12 PM   #7
fledonfoot
Drives: Asphalt FR-S
Check the battery.
My battery failed after about 6500 miles and it threw the startability code and ran like general crap. Battery was struggling at under 8V. Replaced it, cleared the code and it's run like a champ since.
fledonfoot is offline   Reply With Quote
Old 06-25-2014, 05:39 PM   #8
tjsmooth25
tjsmooth25's Avatar
Drives: red/black
Originally Posted by fledonfoot View Post
Check the battery.
Battery is good, they are checking the grounds and the crossover fuel pump now
p0198 code oil temp sensor malfunction circuit high kingkai23 Forced Induction 10 06-17-2014 01:22 PM
Drive-ability Issue SubaSteve Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 05-06-2014 03:02 PM
ecutek ability to adjust to different % of E85 Mars2 Software Tuning 2 12-15-2013 01:04 PM
Engine Check Light: P1604 Startability Malfunction alakim Engine, Exhaust, Transmission 5 09-09-2013 08:46 AM
First Malfunction? Ishii Motors Scion FR-S / Toyota 86 GT86 General Forum 6 06-09-2012 12:16 PM
