Old 10-13-2016, 12:07 PM   #1
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
CEL Code P0700 and P2757
Some background. Car is 31k miles with around 12k boosted miles and automatic. I haven't done tranny fluid/diff fluid flush yet. I'm PRAYING to the 86gods that switching the fluids will fix the issue.
I normally drive in the semi auto mode using the shifter and for a while now, it's some times stuff when I shift, I just thought it was normal. Recently, whenever I shifted into 4th and was in the lower range of rpms, the CEL would show up. The car would drive normally, but whenever you downshift, the car doesn't rev match as good as before (doesn't blip as hard)
Has anyone else experienced these issues or have a fix? I checked the forums about the possible hard shifting issue, but after calling my local Subaru dealership, they wouldn't be able to do anything about it since it was meant for the '15-'16.
Soloside is offline   Reply With Quote
Old 10-14-2016, 01:22 AM   #2
Fenix
Fenix's Avatar
Drives: 2013 Scion FR-S + 2011 Yamaha R6
You changed the transmission out at some point? Why?
How long have you had your current one?
Did you buy it new?
Do you have the old one?
Fenix is offline   Reply With Quote
Old 10-14-2016, 12:52 PM   #3
Soloside
Did you buy it new?
Never changed the transmission.
Old 11-21-2016, 02:11 AM   #4
HaloFRS
Drives: 2020 Subaru BRZ Limited
Had the same code last night driving in the freeway. Same
Status. Boosted and auto. Stopped and turned the car off to gas up and when i fired her up back again it was gone. Did you figure yours at?
Thanks
HaloFRS is offline   Reply With Quote
Old 11-21-2016, 02:33 AM   #5
thecarfilmer
IG: @nickwiththefrs
thecarfilmer's Avatar
Drives: 2016 Scion FR-S Halo
i believe the P0700 is a transmission control unit communication issue. It happened when i once flashed my ECU from an OFT tune. I cleared it with my OFT and hasn't came back since. The rev matching issue happens when the CEL is on
thecarfilmer is offline   Reply With Quote
Old 01-27-2017, 09:42 AM   #6
Soloside
Was able to upgrade the torque converter from levelten thinking that was a fix for the issue. It wasn't. \0/
The shop that I took it to told me to sent him a snapshot of my "calculated torque table"? I'm hoping it's easily found on ecutek. The guy said that some of the numbers might need to be changed to accommodate the increase in power.
Lean Code and 02 Code diagnostics. Kiske Engine, Exhaust, Transmission 12 04-28-2016 10:19 PM
P0700 Code after reading ecu with OFT FRSBRZGT86FAN Software Tuning 2 05-28-2015 01:43 PM
CEL code ChandlerSwyng Issues | Warranty | Recalls / TSB 2 04-08-2014 01:27 AM
P0700 -- auto tranny slip? phrosty Issues | Warranty | Recalls / TSB 6 03-28-2014 11:50 AM
C1294/U0100/P0700 Nightbringer Issues | Warranty | Recalls / TSB 0 07-06-2013 08:18 PM
