Old 11-05-2016, 08:07 PM   #1
xcuz31
Drives: white frs
P0700 CODE AFTER OFT TUNE (AT TRANS)
i have read this always happen to automatic frs to tune with oft but i was wondering what is the solution for this cause i reset it back to stock and still showing codes
i also cleared it with oft and it came back after 20 miles of driving
if anybody knows the fix for this it will be greatly appreciated
i know my transmission is not shot or anything it only happened after oft reflash
xcuz31 is offline   Reply With Quote
Old 11-05-2016, 09:06 PM   #2
steve99
It just a code that is caused by the ecu and auto trans computers not talking during the reflash process.
A couple of drive cycles it should come good.
OFT wont clear trans computer codes only ECU codes, if you have torque app and obd dongle torque app will clear it.
Or just remove battery terminal , press brake pedal and reconnect, but you will loose your audio system setting, clock etc settings that way.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
KalbiCool88 (11-28-2016), xcuz31 (11-05-2016)
Old 11-05-2016, 09:30 PM   #3
xcuz31
Drives: white frs
ok thanks will try if it will fix it .
hopefully i dont need to bring it to the dealer
Old 11-05-2016, 09:33 PM   #4
steve99
no need for dealer mate, its all good happens almost every time you flash auto cars.
nothing wrong its just due to the interruption to communications between the auto computer and the engine ecu during the flash process.
don't panic :-)
Old 11-05-2016, 11:29 PM   #5
xcuz31
Drives: white frs
don't panic :-)
I was just worries cause it went away the. It came back and it shifts weird now and rev match is gone hopefully it gets fixed
Old 11-06-2016, 12:07 AM   #6
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Unplug whatever you have in the obd port because the connection is rubbish.
The Following User Says Thank You to Wayno For This Useful Post:
xcuz31 (11-06-2016)
Old 11-06-2016, 01:02 AM   #7
xcuz31
Drives: white frs
I dont have anything plugged in except for the oft and I unplugged it after i flash my ecu
Old 11-06-2016, 03:07 AM   #8
Wayno
Wayno's Avatar
It should never happen on its own unless there's something wrong with the canbus.
Never connect or disconnect anything while the car is running.
Boomerang (11-06-2016)
Old 12-23-2016, 05:54 PM   #9
KalbiCool88
KalbiCool88's Avatar
Drives: 2005 SLK350, 2015 RS 1.0 FRS
Were you able to resolve your issue? @OP
KalbiCool88 is offline   Reply With Quote
Old 10-20-2017, 08:55 PM   #10
Kurai Ninja
Drives: '17 86
Yea I currently have the same problem. Just flashed back to stock for a dealer visit about my crickets tomorrow and now I have this check engine light. Not the best situation huh?
Sent from my Pixel using Tapatalk
Kurai Ninja is offline   Reply With Quote
Old 10-20-2017, 09:14 PM   #11
Kurai Ninja
Drives: '17 86
From what I've read so far, it's caused by unplugging while ignition is on. Very well could be my case as I've cleared the code and drove it for a bit and everything seems fine.
Old 12-10-2019, 04:48 PM   #12
shadowfax
Drives: 2016 Scion FRS
2016 SCION FRS Automatic Transmission OFT
I own a 2016 Scion FRS Automatic Transmission.
I will be installing tomei expreme uel catless header this coming Friday.
In order to prep, I went ahead and read my stock tune on the OFT.
After I was done reading the stock tune, a CEL appeared. Is it to be expected a CEL will appear after each time you use the OFT on an automatic transmission FRS? I’ve heard from other posts this CEL will go away after a couple drives.
Now that the CEL is on, there is a jerk every time I am coming to a complete stop. Is this normal as well with the CEL on? (Is this what LIMP MODE is?)
shadowfax is offline   Reply With Quote
Old 12-10-2019, 05:36 PM   #13
Alpha86
Drives: 2013 Firestorm Red FRS
Weird throttle response is normal, every time you reflash the ECU or even leave the battery disconnected for long enough, the car has to re-learn certain parameters. It goes away after a few days of driving.
Alpha86 is offline   Reply With Quote
CEL Code P0700 and P2757 Soloside Engine, Exhaust, Transmission 5 01-27-2017 09:42 AM
OFT CEL Code reading clearing - reset tune? Walla Walla Software Tuning 4 08-13-2016 12:02 AM
P0700 Code after reading ecu with OFT FRSBRZGT86FAN Software Tuning 2 05-28-2015 01:43 PM
FS: Ecutek Cable and 93/E85 Tune for Auto trans JoeBoxer Engine, Exhaust, Bolt-Ons 19 02-08-2013 06:00 PM
P0172 Code with Injen Intake, will EcuTek tune help? ron_jeremy Engine, Exhaust, Transmission 0 11-27-2012 11:22 AM
