| Software Tuning Discuss all software tuning topics. |
Drives: 2013 FRS
wideband 02 sensor + ECU
does the ECU need access to a wideband O2 sensor for the car to function better... or is it used in conjunction, in tuning the car with stock o2 sensors. I've bought a wideband sensor and gauge... I know it can be logged but is it possible or beneficial to have it tied into the ECU?
I couldn't find any threads on this topic if you could link me would be great Thank you for any response |
#2 |
Drives: brz 2017 hksv2
you can force the ecu to use it during open loop state of the ecu, the ecu will apply then a closed loop correction into the open loop using your wideband
thwre are failsafe but best usually, and how it ia used by many tuner, is that you use your wideband as a reference to rescale the stock lambda and make. it similar to the wideband using the stock one |
| The Following User Says Thank You to tomm.brz For This Useful Post: | Longuy (05-05-2022) |
#3 |
Drives: 2013 FRS
I see how it works now... I found it in the ProECU help file
thanks again for your reply
| The Following User Says Thank You to Longuy For This Useful Post: | tomm.brz (05-06-2022) |
| Wideband sensor | tofurun | Engine, Exhaust, Transmission | 2 | 02-11-2017 11:42 AM |
| Wideband 02 sensor purpose? | wbradley | Forced Induction | 11 | 08-17-2016 12:04 PM |
| is the front o2 sensor a wideband sensor? | mad_sb | Engine, Exhaust, Transmission | 19 | 12-13-2015 03:20 PM |
| Where does wideband O2 sensor go? | Turbowned | Forced Induction | 8 | 08-29-2014 03:16 PM |
| LC-1 wideband 02 sensor | MattF | Engine, Exhaust, Bolt-Ons | 4 | 11-05-2013 10:52 PM |
