Old 10-24-2018, 10:57 PM   #1
stlgrym3
First oil change parts question
Following are the items I’m about to purchase for the first oil change on my BRZ. The Motul 0w20 is labeled as High RPM racing motor oil, is this the right variant of Motul for our car? Does the bundle include the crush washer?
stlgrym3 is offline   Reply With Quote
Old 10-24-2018, 11:16 PM   #2
new2subaru
Weight Weenie
Drives: 15 FR-S
What you have there is fine. How many 2 litre containers of oil did you order? You'll need 3.
Old 10-24-2018, 11:21 PM   #3
stlgrym3
I have not placed order yet must putting them in cart first. So does the crush washer come with this bundle?
Old 10-24-2018, 11:30 PM   #4
new2subaru
Weight Weenie
Drives: 15 FR-S
It appears so. They're just calling it a gasket, which the name used by Subaru
EDIT It's the correct part number https://parts.subaru.com/p/Subaru__/...803916010.html
The Following User Says Thank You to new2subaru For This Useful Post:
stlgrym3 (10-24-2018)
Old 10-24-2018, 11:43 PM   #5
stlgrym3
For this particular version of Motul oil, does the words “high rpm” matter? Is there another version of this 0w20 by the same brand?
Old 10-25-2018, 06:46 AM   #6
JIM THEO
Drives: BRZ 2018
As this V300 is too thin they mean it favors high revving than a thicker oil!
JIM THEO is offline   Reply With Quote
Old 10-25-2018, 07:22 AM   #7
86MLR
86MLR's Avatar
I wouldn't use that in a street car, that oil is designed to be used hard, then swapped out.
It favors hp gains over wear.
Unless you plan on changing your oil alot.
Or because racecar.
There is heaps of info IRT on the webs.
The Following User Says Thank You to 86MLR For This Useful Post:
humfrz (10-25-2018)
Old 10-25-2018, 08:43 AM   #8
stlgrym3
Or because racecar.
Which brand does the dealer use? I have an aftermarket header and flex fuel kit, so I do run on e85 sometimes, does that matter which type of oil to use? Can I just get the same oil dealer used?
Old 10-25-2018, 09:16 AM   #9
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
Any GF-5 oil will likely treat you fine as long as it's 0w20. If you want some good stuff a lot of people here like the Amsoil signature series or Motul 8100, but I believe Mobil 1 is a popular off the shelf oil used among 86 people. It really depends on how often you wanna change it and what you use the car for.
MCTeeJ is offline   Reply With Quote
The Following User Says Thank You to MCTeeJ For This Useful Post:
stlgrym3 (10-25-2018)
Old 10-25-2018, 11:53 AM   #10
Tristor
Tristor's Avatar
If you're primarily driving on the street and want to keep the recommended 5000 mile oil change interval, you should definitely not use the Motul 300V, as it is not intended to be used on street cars for the long term. It's a racing oil designed to be changed between track events. As someone else mentioned Mobil 1 is a pretty easy to get, inexpensive, and perfectly reasonable option in a street car. I personally use AMSOil, although it's kind of expensive, I like it well enough.
What tells you if you need to up your OCIs or have unusual wear from E85 is getting a used oil analysis done.
Tristor is offline   Reply With Quote
Old 10-25-2018, 02:24 PM   #11
IMHO, it don't really matter. Any name brand, full synthetic, 0W-20 oil will do.
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Mr.ac (10-25-2018), new2subaru (10-25-2018), Tristor (10-25-2018)
Old 10-25-2018, 06:07 PM   #12
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
My current oil of choice is Idemitsu Zepro 0W-20 Eco Medalist
One of only 2 0W-20 oils that are ~35 cSt at 40°C (vs market avg of ~45 cSt at 40°C, the other is Toyota Genuine Motor Oil 0W20).
Makes my engine feel butter smooth and +2 mpg.
I had to relearn the NVH from my engine after changing to this oil because I had less engine vibration.
Try it while they're cheap sub $30 .. I've seen them go up to $33. I grabbed 3 5 quarts at $25. I should have pre-ordered when it was $20.
https://www.amazon.com/ZEPRO-3001009...tsu+0w-20+zero
Old 10-25-2018, 07:41 PM   #13
Rabidpug
Rabidpug's Avatar
Drives: 2017 BRZ Limited
the Subaru dealership I purchased my car from last month put full synthetic 0w-20 castrol edge in the engine. Seems to be holding up well.
Rabidpug is offline   Reply With Quote
Old 10-25-2018, 10:16 PM   #14
stlgrym3
I found some unused Mobile 1 0w20 purchased for my 2018 Camry. Can I use these on my BRZ?
JRSC traction fluid change question Infidel86 Forced Induction 1 12-20-2016 12:10 PM
Oil change and filter question pooch Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 09-04-2016 09:49 AM
Oil Brand/Oil Change question Ginger Academy Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 11-23-2015 10:43 PM
e85 tune. change rubber parts? asphalt_fr-s Software Tuning 5 03-25-2014 12:28 PM
oil change question jarviz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 07-19-2012 07:14 PM
