Old 12-18-2016, 09:28 PM   #1
Infidel86
Drives: 2013 GBS BRZ
JRSC traction fluid change question
What's the best method that you guys discovered to change the traction fluid? Is there an alternative to removing the oil cooler?
Infidel86 is offline   Reply With Quote
Old 12-20-2016, 11:10 AM   #2
empower-auto
Kouki-Monster
empower-auto's Avatar
I drain from resi and refill, then cycle it. Do at half intervals versus a normal change and you're good
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
The Following User Says Thank You to empower-auto For This Useful Post:
Infidel86 (12-28-2016)
Speed Academy EP5 - JRSC dyno (updated: EP6 - JRSC Track Test) DarkSunrise Scion FR-S / Toyota 86 GT86 General Forum 17 03-30-2017 11:39 PM
Tires to help with traction after JRSC install arren123 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-02-2017 01:13 PM
AT Fluid Change? Estey Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 45 10-23-2014 09:55 PM
AT Fluid Change Terrapin77 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 08-29-2013 09:52 PM
Fluid change siXXtoes Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-06-2012 09:39 AM
