Old 05-10-2018, 10:31 AM   #1
paintdude258
paintdude258's Avatar
BRZ passenger window will not pair!
What is going on my BRZ and FRS Brotheren?
I know what your thinking, this idiot just needs to pair his window by holding down the window switch for 5-10 seconds and then repeat on the way up.
I know this process and have had great success with this process in the past, but after 3 months of repeated attempts, i am turning here for help.
I have the typical, flashing light on the passenger window switch, window valet not working and leaving the window down after anyone opens the passenger side door.
This all started when i replaced the speakers in each door. I took off both door pannels, sound deadened them, and put them both back together without issue.
Thoughts: Could the rubber window seal that the window goes into when you roll it up be causing a jam? Could a screw have come loose and caused the window itself to loose it's mounting position?
Any help will be greatly appreciated.
Thanks guys,
Balakay!
paintdude258 is offline   Reply With Quote
Old 05-10-2018, 10:41 AM   #2
Thanks guys,
Balakay!
Loads of things could be going on inside there. Could have dislodged a wire, something jamming the mech, could be misaligned, etc. Only way to find out is to pull the door panel again and take a look.
humfrz (05-10-2018)
Old 05-10-2018, 01:18 PM   #3
paintdude258
I completely agree that there could be a multitude of things happening, especially since it let me pair the window once about a month ago, but it immediately jammed and stopped working the next use.
I have pulled the panel off three times now, checked all wires, and i even purchased and installed a whole new window up/down switch that helped none.
I have checked to make sure the window is not touching anything, relocated all wires to be completely out of reach of the window, and still nothing.
The Following User Says Thank You to paintdude258 For This Useful Post:
Tcoat (05-10-2018)
Old 05-10-2018, 02:04 PM   #4
Icecreamtruk
Drives: Track preped NA FRS
My driver window stopped pairing as well, but I have no blinking light. The window just doesnt move up/down when opening or closing the door. Mine is almost full on racecar by now, so I just let it be. It started happening after I had a rollbar installed, so maybe some wired got cut or moved or something, as @Tcoat suggested.
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Tcoat (05-10-2018)
Old 05-10-2018, 02:05 PM   #5
wbradley
Sarcastic SOB
wbradley's Avatar
Toyota service?
The Following User Says Thank You to wbradley For This Useful Post:
Tcoat (05-10-2018)
Old 05-10-2018, 02:18 PM   #6
Originally Posted by wbradley View Post
Toyota service?
Our an auto glass place. If all the obvious has been exhausted may be time to let the experts look at it. I will weld in a whole new floor pan or completely rebuild an engine but won't even attempt glass work beyond the basics. It is a black art.
jam, jammed, pair, window
my passenger window does nothing lucy86brz Electronics | Audio | NAV | Infotainment 0 01-25-2018 10:59 PM
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 03:14 PM
Passenger Window Sailors14FR-S Issues | Warranty | Recalls / TSB 10 05-04-2014 11:28 PM
passenger window reset?? damaster32 Issues | Warranty | Recalls / TSB 3 03-25-2014 01:00 PM
Passenger Window Switchs Out LarryGP Issues | Warranty | Recalls / TSB 10 11-13-2012 07:04 PM
