Old 11-29-2013, 11:36 PM   #1
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
So i broke my wheel speed sensor
Idk which wheel, but at a track day today i went off into the dirt fairly hard, broke the sensor and hopefully only my alignment and nothing suspension related since my steering wheel is crooked now. Are the speed sensors dealership only? If so how do i replace them? Are they just plug and play?
bkblitzed is offline   Reply With Quote
Old 11-30-2013, 12:27 AM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I had to replace one on my sti before and it was plug and play. Imagine it shouldnt be too different.
And yeah, dealer only. Best bet is prob online since the dealer is gonna have to order it anyway.
bkblitzed (11-30-2013)
Old 12-01-2013, 12:04 AM   #3
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
You can order them online from a oem parts dealer (ie. 1stToyotaParts.com) and they're $103.97 each.
SU003-00663 - Front LH speed sensor
SU003-00662 - Front RH speed sensor
SU003-00665 - Rear LH speed sensor
SU003-00664 - Rear RH speed sensor
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
Old 12-01-2013, 01:13 PM   #4
bkblitzed
is better than you
bkblitzed's Avatar
holy shit they're expensive
here's a pic of the steering wheel
Old 12-01-2013, 05:00 PM   #5
azian_advanced
*****istrator
they're actually cheap imo. i'm used to them being around $150-$200 each for my previous toyotas.
anyway, your first step is to read the code and find out what exactly is causing the ABS light to appear. it's probably just a torn ABS wire.
Old 12-01-2013, 10:52 PM   #6
bkblitzed
is better than you
bkblitzed's Avatar
the lights turned off today, im guessing they can be reset within a certain amount of cycles? I could turn off trac and vsc. So im guessing its only an alignment issue
Old 12-02-2013, 10:12 AM   #7
ML
ML's Avatar
Drives: 13 White MT FR-S
I got off ebay for like $40, and it just plugged right in.
Old 12-03-2013, 01:41 AM   #8
bkblitzed
is better than you
bkblitzed's Avatar
thankfully i didn't need new sensors. My toe was really fucked up lol. My FR was -1.2 and my FL was +1.4
Old 12-03-2013, 08:49 AM   #9
ML
ML's Avatar
I had to read this a couple times to understand why your toe was fucked up...need more caffeine. thats crazy though.
Old 11-18-2016, 04:04 PM   #10
DAEMANO
Time Traveller
Necro.... How long did you have to drive it before the light went off after changing the sensor? When you were driving the car was it in limp-home mode?
Speed Sensor Bases Limp mode after new tires MrSlay Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 03-30-2018 10:31 PM
Fuel pump and speed sensor Tt3Sheppard Issues | Warranty | Recalls / TSB 28 04-20-2017 01:54 PM
Noise when turning steering wheel at low speed Slant Issues | Warranty | Recalls / TSB 7 11-06-2015 08:53 AM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
Recommendations to a speed/wheel/tire shop around orange county?? eddieEndo Southern California 6 02-10-2013 07:36 AM
