Old 10-25-2013, 07:26 PM   #1
MrSlay
Drives: Gx 460, FRS, Prius
Speed Sensor Bases Limp mode after new tires
Installed the rear tires on my wheels today (285/40/18) and the car soon went into a Speed Sensor based limp mode. Abs, Hand Brake, Power steering, and a few more lights Christmas treed the dash while vehicle speed read 0 as the car was doing about 60mph.
My friend also had the same issue with his initial set of tires as they was about a 9% difference in diameters between the front and rear tires. He fixed the issue with a new set of tires that are now have about a 2% difference in diameter.
Question here is if anyone knows the minimum ratio/percentages that will satisfy the electronics on the car. I have a set of tires set to come in on Monday that are 7.2% smaller than my rear tires and really don't want to mount them if there not going to work.
Thanks In Advance
15 FRS
12 Prius
12 ISF
15 Gx 460
My YouTube Channel
MrSlay is offline   Reply With Quote
Old 10-25-2013, 11:58 PM   #2
JerryMichaels7
Drives: Whiteout FRS
holyshit you fit 285s???
JerryMichaels7 is offline   Reply With Quote
Old 10-26-2013, 08:08 AM   #3
MrSlay
Ya, thankfully my measurements were right and they were no problem. I could even run a 305 If I were to roll the fenders.
15 FRS
12 Prius
12 ISF
15 Gx 460
My YouTube Channel
Old 01-21-2014, 07:48 PM   #4
no chrome
She said member
Drives: fr-s firestorm
Thanks In Advance
did you try it with 7.2% difference?
did that trigger limp mode?
i'm considering a 5% diameter difference front to rear
anyone running that right now?
if we all hit limp mode, maybe custom tone rings would work?
no chrome is offline   Reply With Quote
Old 01-21-2014, 07:57 PM   #5
Dwood11
Dwood11's Avatar
Drives: 2014 SWP BRZ LIMITED
Um I second that. Impressive, most impressive. I am thinking of going 235 or 245. Now those sizes just seem puny. Props man. How much do those bad boys weigh, wheel and tire together. You gotta be feeling some power loss there. How does the car feel in terms of that? I am really curious.
Dwood11 is offline   Reply With Quote
Old 01-21-2014, 11:26 PM   #6
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Power loss? oh yeah, he neutered it.
lol @wparsons made a good point. If he has that much power, he needs that girth
Old 01-22-2014, 07:09 AM   #7
wparsons
wparsons's Avatar
^^ If his signature is even remotely accurate, he'll need 285's or bigger
flickr
Old 01-22-2014, 12:39 PM   #8
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
haha waaaaaaaait TOUCHE.
Old 01-22-2014, 08:05 PM   #9
AtlasMick
Drives: FR-S 2013 Asphalt
What can you do to correct the limp mode? The computer runs it, if you can tune the ECU for emmissions and timing couldn't you also tune it to fix speedo and traction control issues associated with larger diameter wheels/tires?
AtlasMick is offline   Reply With Quote
Old 02-14-2014, 06:44 PM   #10
Crazy Drew
Drives: Smells like tires when I drive
+1 was this ever resolved without changing tire size?
I'd like to run 18/19 stagger and I can't really do this without concerns about what you had going on.
Crazy Drew is offline   Reply With Quote
Old 05-01-2014, 08:15 AM   #11
diss7
Drives: AE86, 2x GT86, TE27
I've run 225/40/18 and 205/40/17 and that causes it.
Also 205/55/16 and 205/40/17 caused it as well.
205/40/17 and 205/50/16 DOESNT do it. Neither does 205/40/17 and 205/45/16
Not running the abs fuse doesn't solve it. It obviously solves the abs from panicking when you brake with such a stagger (because pulling the fuse disables the pump) but it'll still set rev limit at 4200 or so, and do weird things with the ps (provides weird levels of assistance at different speeds.
diss7 is offline   Reply With Quote
Old 03-30-2018, 10:02 PM   #12
adjusts
adjusts's Avatar
Drives: 86
did this ever get resolved? do you know the maximum difference that is acceptable?
adjusts is offline   Reply With Quote
Old 03-30-2018, 10:31 PM   #13
adjusts
adjusts's Avatar
Drives: 86
did you have issues with 5% diameter? I'm interested in how this turned out.
Dead battery; starts up in limp mode kilrb Issues | Warranty | Recalls / TSB 15 01-04-2018 02:54 PM
Fuel pump and speed sensor Tt3Sheppard Issues | Warranty | Recalls / TSB 28 04-20-2017 01:54 PM
Car in Limp mode... No CEL Sportsguy83 Issues | Warranty | Recalls / TSB 60 08-20-2014 03:35 AM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
Beast Mode: Do You Like Your Tires Beefy? @Pure Automotive Pure Automotive Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 03-20-2013 11:00 PM
