Hot Lava 6MT
Drives: Hot Lava FR-S
How did you wire your new speakers?
To those of you that installed a new set of speakers/amp, how did you wire them?
#2 |
AutoX-10/10ths every run
RCAs from the deck to the sub amp. Vampire taps for the separates in the doors in conjunction with some aftermarket adapters.
#3 |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Haven't done mine yet but I'm running RCAs/rem wire back to the amps, then all new wiring to the speakers from the amps. Going to just disconnect the stock wiring and leave in place in case I ever go to remove my system or change to something else.
#4 |
Hot Lava 6MT
#5 |
Hot Lava 6MT
That was what I originally wanted to do, however I couldn't figure out how to get my wire in passed the door molex.
#6 | |
[ame="http://www.amazon.com/gp/product/B0002BBP7Y"]Amazon.com: Metra 72-8104 Speaker Connector for Select Toyota Vehicles: Electronics[/ame] I then just vampire tapped into the end of the wires coming off this harness. As for the deck connections, I'm running all of the stock/aftermarket speakers off the deck using an adaptor and the factory harness . I'm only running my subs off an AMP that I've mounted in the trunk.
| The Following User Says Thank You to whataboutbob For This Useful Post: | lordtakuban (01-17-2013) |
#8 |
Hot Lava 6MT
#9 |
Drives: Argento 6spd FR-S
#10 |
Hot Lava 6MT
#11 |
I ran all new.
To get it through the door I just un hooked the rubber boot and fished it through. sometimes a metal close hanger can be used if needed but I didn't have to go that far. |
#12 |
Hot Lava 6MT
Unhook the boot and start fishing? Fish in the boot right? I'll give it a shot this weekend.
#13 |
Drives: 2013 Subaru BRZ Limited in WRB
Go in your closet and grab an old metal hanger. Untwist the hook end and you'll have a great wire puller. Just be careful as the edges can be sharp and puncture existing wires ...don't go shoving it in.
Fish the hanger through, tape your wires to the end, lube it up with some spit and pull it through.
#14 |
Hot Lava 6MT
| Wire Tuck | DIM | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 08-11-2013 05:54 PM |
| best way to install 12v wire for amp?? | derka-derka | DIY (Do-It-Yourself) Guides | 5 | 03-17-2013 01:57 PM |
| Dash Top Speakers / Rear seat speakers | Laurie | Electronics | Audio | NAV | Infotainment | 9 | 03-01-2013 07:31 PM |
| wire routing for door speakers | derka-derka | Electronics | Audio | NAV | Infotainment | 6 | 12-13-2012 10:49 PM |
| Reverse Wire Tap wire Location? | Norkoastal | Electronics | Audio | NAV | Infotainment | 2 | 10-19-2012 11:22 AM |
