Old 05-11-2014, 08:29 PM   #1
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
Alignment question?
I have a brz limited with tarmac 2 coilovers and raceseng camber plates with a aftermarket rear control arm.
Tires are bridgestone re-11 255-35-18
I'm looking for a street/ track ready car.
Any alignment suggestions.
@CSG Mike
cjsporl1996 is offline
Old 05-11-2014, 09:22 PM   #2
CSG Mike
CSG Mike's Avatar
Default spring rates?
-3.3 camber 6.8 caster 0 toe front
-2.7 camber 1/16" total toe out rear.
This is a track alignment specific to the RCE T2, for experienced drivers.
Reduce camber in the rear slightly if you feel the car is too loose on corner exit
CSG Mike is offline
Old 05-11-2014, 10:00 PM   #3
cjsporl1996
I was looking for a hybrid setup that would work well on the streets and on a hpde event. 400 spring rates
Old 05-11-2014, 10:14 PM   #4
dp1
driving smoother faster
Drives: Sold
Alignment question?
I use -3.4f -2.7r with Ohlins R&T per Mike's recommendation on Michelin PSS 225/45R17 and 7.5in rims on street and Toyo Proxes RA1 235/40R17 and 8in rims on track, with extra 2deg caster in front and no toe, somewhat lowered, and love the setup on street and especially on track. Track photo of my car in a fast turn shows wheels have good angle under compression (could have gone 10mph+ faster). I do experience some push on grooved highways and a little bit of wiggle on power in straight line with JR SC but this is a fantastic set up for me on track. Not the same setup as yours but FYI.
dp1 is offline
Old 05-11-2014, 10:22 PM   #5
CSG Mike
CSG Mike's Avatar
You can't have your cake and eat it to... something's gotta give.
Zero out the toe in the rear for street use, or 1/16" total toe in front AND rear for stability. it'll hurt cornering at the track.
Do you want street stability or on-track grip?
CSG Mike is offline
Old 05-11-2014, 10:49 PM   #6
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
What camber settings do you recommend for RCE Yellows?
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline
Old 05-11-2014, 11:06 PM   #7
CSG Mike
CSG Mike's Avatar
Springs? They're non-adjustable. Do you have LCA and camber plates? (I'm guessing probably not, each of those supporting components cost 2-3x what the springs cost).
CSG Mike is offline
Old 05-11-2014, 11:10 PM   #8
zdr93523
zdr93523's Avatar
Yes, HVT camber plates, SPC camber bolts, and rear LCAs. I did not want coilovers since the car is a DD, but I wanted to be able to have a legit track alignment. So yes... my alignment is fully adjustable.
www.makesmodels.com
www.camautomag.com
zdr93523 is offline
Old 05-11-2014, 11:37 PM   #9
CSG Mike
CSG Mike's Avatar
Woah. You get mad props sir.
Start at -3 in the front and rear. Get some pyrometer temps, and get back to me. It'll be much more willing to rotate than stock, but may feel "loose" to you due to the huge weight transfers from the increased grip.
CSG Mike is offline
Old 05-11-2014, 11:50 PM   #10
zdr93523
zdr93523's Avatar
Thanks for the props! I'm doing a PCA HPDE day on June 7th at Miller Motorsports Park. I'll let you know how it does.
www.makesmodels.com
www.camautomag.com
zdr93523 is offline
Old 05-12-2014, 12:08 AM   #11
zdr93523
zdr93523's Avatar
I'm planning on buying tires before the event. 225 or 245s on 17s. Do you have a tire suggestion. I was looking at trying the Cooper RS3-S. They seem comparable to Hankook RS3s according to reviews but are very affordable. Any thoughts?
Also, should I buy some lightweight 17x8s (that was my initial plan), 17x9s, or just throw the tires on the OEM wheels? I have another set of wheels that I use for DD so these will be strictly for my track tires.
Edit: This is a NA build. ~200whp
www.makesmodels.com
www.camautomag.com
zdr93523 is offline
Old 05-12-2014, 11:30 AM   #12
zdr93523
zdr93523's Avatar
@CSG Mike I'm running Eibach sway bars too. Will it be too loose at -3 degrees camber in the rear with the bars. I'm going to start with them both set to soft.
Sent from my LG-D800 using Tapatalk
www.makesmodels.com
www.camautomag.com
zdr93523 is offline
Old 05-12-2014, 01:35 PM   #13
CSG Mike
CSG Mike's Avatar
225/45/17 on 17x8 RS3 will be plenty.
Coopers are NOT comparable.
The car will only feel overly loose if you're swinging the weight around. Smooth, controlled inputs are key.
CSG Mike is offline
Old 05-12-2014, 04:00 PM   #14
zdr93523
zdr93523's Avatar
Thanks for all of the input. I'll get the alignment dialed in prior to the HPDE day. I'll probably burn up the stock Primacy's and then get a dedicated set of wheels and RS3s. I'll report back with tire temps once I get it out on the track.
www.makesmodels.com
www.camautomag.com
zdr93523 is offline
alignment, hpde
Alignment Question and issue whitefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-31-2014 07:42 AM
brz alignment question Shenks BRZ First-Gen (2012+) — General Topics 2 02-12-2014 09:23 PM
Rear Camber/Alignment Question anewprelusion Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-25-2013 11:39 PM
alignment question hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-15-2013 12:52 PM
Alignment question retrosmiths Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-11-2013 10:44 PM
