Old 04-14-2013, 05:33 AM   #1
deedz
Drives: Rocket Bunny FR-S
Moving in neutral....Engine turns off?
So this has been happening since I can remember every once and a while but the other day it happened twice in 2 minutes
Basically at 40mph I popped the car into neutral and all of a sudden the engine turned off and rpm dropped. A bunch of lights showed up like the TAC sweep lights ( tracation control, battery light, oil light, ABS light, engine light and the steering wheel light) so while i was moving in neutral I started the car again. Then another minute later I come to a complete stop and put the car in neutral again and the car turns off...it kind of concerns me that this has happened multiple times and I have no idea what it may be? Anyone experiencing similar issues?
deedz is offline   Reply With Quote
The Following User Says Thank You to deedz For This Useful Post:
Guff (04-14-2013)
Old 04-14-2013, 05:58 AM   #2
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
New start/stop feature?
I'm not sure what it is, but you should def. get it checked out by the dealer, sounds like a bad problem. It def. shouldn't be doing that from just going in Neutral.
- The Ancient BRZ Sacrament
by Zaku
The Following User Says Thank You to Guff For This Useful Post:
dori. (04-19-2013)
Old 04-14-2013, 10:22 AM   #3
Steve
Steve's Avatar
Drives: 6MT
Are you leaving it in neutral at 40mph and coasting?
Steve is offline   Reply With Quote
The Following User Says Thank You to Steve For This Useful Post:
strat61caster (04-14-2013)
Old 04-14-2013, 12:24 PM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Manual or Automatic?
ineedyourdiddly
Old 04-14-2013, 01:16 PM   #5
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Intake modifications?
CircuitJerk is offline   Reply With Quote
Old 04-15-2013, 05:16 PM   #6
deedz
Yea i pop it into neutral to coast for a second or even when im slowing down from 5th gear to a stop, before the rpm drops low I just pop it into neutral
manual
I have an injen intake
Rocket Bunny Vinyl Wrapped Build Page:
http://www.ft86club.com/forums/showthread.php?t=33573
Old 04-15-2013, 05:22 PM   #7
strat61caster
Sounds like an ECU issue, take it into the dealer and if they're stumped I would ask for a reflash.
The car isn't holding idle rpm's, that's a problem on a brand new computer controlled car, warranty should take care of it. This is assuming the only mod is the intake of course.
ineedyourdiddly
Old 04-15-2013, 06:37 PM   #8
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
I have seen this happen on a BRZ with an Injen intake.
Suggest you re-install the stock intake and try to reproduce the issue.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
The Following 4 Users Say Thank You to deucethemoose For This Useful Post:
CamryDS (04-15-2013), jonnyozero3 (04-19-2013), SloS14 (04-15-2013), Subie (04-15-2013)
Old 04-15-2013, 06:57 PM   #9
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
That injen sure is some trouble from what I read on here.
Rayme is offline   Reply With Quote
Old 04-15-2013, 07:06 PM   #10
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Get to dealers asap imo.
Old 04-15-2013, 07:07 PM   #11
CircuitJerk
Pull my finger...
My suggestion would be to reset the ECU by removing the negative cable from the battery and then go over your Injen installation thoroughly. Once you've checked your installation, and you're confident everything is in place and there's nothing unusual, press your horn, turn on your headlights to purge any remaining power from the electronics, wait 5 minutes or so and then reconnect your battery.
If the problem persists try putting the stock intake back on and see if you can duplicate the issue like @deucethemoose suggested.
The Following 3 Users Say Thank You to CircuitJerk For This Useful Post:
deedz (04-19-2013), deucethemoose (04-15-2013), SloS14 (04-15-2013)
Old 04-15-2013, 07:10 PM   #12
FRSPirate
FRSPirate's Avatar
Drives: 13 Scion FRS Raven M/T, 05 Raven R6
I wouldn't take it to the dealer until you made sure it's not the intake. I can almost bet it is; the same thing use to happen on my Z and it was pop charger related.
-Alex
05 Raven R6
13 Raven FRS M/T
FRSPirate is offline   Reply With Quote
The Following 2 Users Say Thank You to FRSPirate For This Useful Post:
CaptainSlow (04-22-2013), Subie (04-15-2013)
Old 04-15-2013, 09:28 PM   #13
Juurian
Juurian's Avatar
Drives: 2013 Scion FRS WhiteOut
i have an injen intake as well this has happened to me once but after the ecu relearned itself i havent had an issue, guess i got lucky.
Winnipeg, Manitoba
Juurian is offline   Reply With Quote
Old 04-15-2013, 09:40 PM   #14
firl21
Drives: Scion FRS in hot lava
IS the injun a short ram or CAI?
Im going to turbo/supercharge my car and i need to know what intakes i need to stay away from
firl21 is offline   Reply With Quote
Beeping after ignition turns off.. chadstyle BRZ First-Gen (2012+) — General Topics 45 07-20-2020 01:53 PM
Engine shaking/vibrations at 1700rpm - when in neutral/idle kharn83 Issues | Warranty | Recalls / TSB 9 11-07-2013 10:00 PM
Auto Climate Control turns on randomly cantaloupe BRZ First-Gen (2012+) — General Topics 18 03-14-2013 08:38 AM
Car rattle at neutral. IloveBaldEagles Issues | Warranty | Recalls / TSB 3 12-23-2012 06:55 PM
FR-S: Highbeam turns on lowbeam, how to disable? civicdrivr Cosmetic Modification (Interior/Exterior/Lighting) 6 07-03-2012 07:08 PM
