follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 13
1
2
3
4
5
11
Last
Showing results 1 to 30 of 366
Search took
0.02
seconds.
Search:
Posts Made By:
RZNT4R
Forum:
Issues | Warranty | Recalls / TSB
11-19-2023, 08:52 PM
8
Trunk to trunk-lid gap, rain water leakage from welds?
1,824
Posted By
RZNT4R
The beige stuff is seam sealer, that's normal....
The beige stuff is seam sealer, that's normal. looks factory, sheet metal also looks fine.
But no, that trunk isn't sealing at all. looking like that from the inside, that trunk lid should be...
Forum:
11-09-2023, 05:57 AM
16
Not blowing any hot air from vents
1,953
Posted By
RZNT4R
- Does air get hotter towards the passenger side...
- Does air get hotter towards the passenger side vents?
- If you turn the car on with no engine and the fan at low speed, can you hear the temperature door swing in the vents if you cange the...
Forum:
10-22-2023, 04:07 PM
7
Hey guys I need help with a code
1,299
Posted By
RZNT4R
Instead of trying parts, try a scan tool to read...
Instead of trying parts, try a scan tool to read live data. You need to know the throttle plate position.
One of the following conditions is met (1 trip detection logic):
The throttle position...
Forum:
08-27-2023, 10:41 AM
4
AC Rattle at 2-2.5k rpm
728
Posted By
RZNT4R
BTW, I was thinking back and I think I should...
BTW, I was thinking back and I think I should expand a bit on my no-DIY stance on AC:
I'm not telling anyone to not repair their AC system themselves, you are allowed to, for example, change a...
Forum:
08-26-2023, 10:25 AM
4
728
Posted By
RZNT4R
That's why I tell people not to DIY AC, it's...
That's why I tell people not to DIY AC, it's already a pain to deal with in a pro setting.
Did you replace components other than the compressor? New/rebuilt compressors usually have more oil in...
Forum:
07-31-2023, 07:30 PM
55
Lock out shifting from 3rd to Second when cold
6,442
Posted By
RZNT4R
Hey, I'll bump this saying, I skipped the...
I skipped the gearbox oil this spring when I was doing my maint because I didn't have enough Amsoil MTG for a full fill. Well I'm on vacation now and decided to sort...
Forum:
07-23-2023, 07:31 AM
55
Another 2nd-gen engine failure at track...
6,688
Posted By
RZNT4R
That's a nice install, and configured like that,...
That's a nice install, and configured like that, accumulator only with a manual valve, is probably pretty cheap and more than enough for the very momentary dips that are being seen.
Forum:
07-17-2023, 09:39 PM
55
6,688
Posted By
RZNT4R
What's fun to consider is that a Ford 6.8 V10 in...
What's fun to consider is that a Ford 6.8 V10 in an E350 has "5W20" on the filler cap, while the same 6.8 V10 in an E450 incomplete chassis has 5W30. I'd wager the main difference between those two...
Forum:
07-16-2023, 06:05 AM
55
6,688
Posted By
RZNT4R
If it's blowing up on right handers, it should...
If it's blowing up on right handers, it should have been caught early on japan, just look at tsukuba. Turn 1, the penultimate hairpin and fast sweeping right leading to the start/finish line should...
Forum:
07-15-2023, 06:59 PM
55
6,688
Posted By
RZNT4R
You guys are arguing a lot about oil weights when...
You guys are arguing a lot about oil weights when GT86 cup cars ran 5W50.
Forum:
07-13-2023, 06:09 AM
8
My turn to make an air conditioning issue thread!
1,078
Posted By
RZNT4R
SAE A/C fittings have an acceptable loss of 1/4...
SAE A/C fittings have an acceptable loss of 1/4 of an ouce per fitting per year.
Forum:
07-12-2023, 06:45 PM
8
1,078
Posted By
RZNT4R
!!! STOP IMMEDIATELY !!! Are YOU trying to...
Are YOU trying to fill it with refrigerant? like those over-the-counter bottles from the auto parts store?
Most of those products have...
Forum:
07-07-2023, 04:37 AM
7
New clutch creaking noise
691
Posted By
RZNT4R
My stock clutch fork does that, I need to get...
My stock clutch fork does that, I need to get around to it.
Put a dab of EP grease on the end of the slave rod, if that doesn't fix it, transmission needs to get pulled off and grease applied to...
Forum:
07-06-2023, 07:35 PM
12
Center dash vents stopped working/ blowing
2,107
Posted By
RZNT4R
Superb :clap: Those basics man, they'll get...
Superb :clap:
Those basics man, they'll get ya everytime.
I have a story of an old man traumatizing tech support for 3 hours on the phone because the support guy or gal forgot to start with...
Forum:
06-29-2023, 09:48 PM
12
2,107
Posted By
RZNT4R
You're going to think I'm making fun of you but I...
You're going to think I'm making fun of you but I have to ask, because skipping the basic, obvious stuff is the best way to waste effort...
The two wheels between the vents have their lines...
Forum:
06-17-2023, 04:51 PM
3
Subaru BRZ 2017 won’t start but crank with a new battery. Need Help!
675
Posted By
RZNT4R
Always start with DTCs. Not likely to be the...
Not likely to be the immobilizer, those things don't just unprogram themselves. I've seen immos fall into theft mode after a certain number of tries with a bad or incorrect...
Forum:
06-10-2023, 09:22 AM
55
6,442
Posted By
RZNT4R
The location of that ball reinforces the...
The location of that ball reinforces the importance of the oil.
On this transmission the 1/2 shift hub is on the layshaft, submerged when the car is parked, and very likely soaking wet with it's...
Forum:
06-02-2023, 09:00 PM
25
Check Engine light and Traction Control Light
33,011
Posted By
RZNT4R
What was causing what? The original poster's...
What was causing what? The original poster's P000A? the other guy's transmission issue?The third guy's EVAP code? This thread is all over the place and the 4th guy writing a dissertation on how to...
Forum:
05-31-2023, 06:29 AM
55
6,442
Posted By
RZNT4R
Pretty much any high quality, modern, synthetic...
Pretty much any high quality, modern, synthetic gearbox lube, not the OE GL-3 stuff.
I can only vouch for Amsoil MTG, other will speak for Motul Gear 300LS, Redline MT90... Take your pick.
Forum:
05-25-2023, 06:08 AM
55
6,442
Posted By
RZNT4R
Gears aren't locked out, gotta rev match it. OE...
Gears aren't locked out, gotta rev match it. OE oil is meh.
Forum:
05-02-2023, 05:50 AM
21
Clutch Replacment?
2,016
Posted By
RZNT4R
If your normal is taking off at 1800, damn, maybe...
If your normal is taking off at 1800, damn, maybe you do have some hot spots because "normal" should be barely above idle...
These cars are actually pretty hard to stall and gladly hook up at idle...
Forum:
05-01-2023, 09:23 PM
21
Clutch Replacment?
2,016
Posted By
RZNT4R
So you say it's slipping, but you describe the...
So you say it's slipping, but you describe the exact opposite.
What do you mean by "If I don't rev it significantly higher than normal" ? What's significant" what's normal? If I had to put words...
Forum:
04-29-2023, 10:28 AM
22
Caliper bracket bolts class action
2,265
Posted By
RZNT4R
Threads stripped, not a broken bolt, wheel...
Threads stripped, not a broken bolt, wheel bearing bolt heads partially rounded, damage to backside of wheel bearing, damage to both inside and outside wheel lips that would not be caused by the...
Forum:
04-23-2023, 04:34 PM
4
P0700 CODE!!!
1,196
Posted By
RZNT4R
This is bullshit. Also, you figured out...
This is bullshit.
Also, you figured out nothing, P0700 tells you nothing, it says "transmission control system" in the engine control module to tell you to go read transmission DTCs in the TCM....
Forum:
04-18-2023, 09:06 PM
489
Registry Thread: Failure After J02 Recall
219,996
Posted By
RZNT4R
Eh, just for fun I'll share. From yesterday,...
Eh, just for fun I'll share. From yesterday, Dodge caravan dropshipped to us from a local dealer. Good ol' reliable, tough as bricks 3.3, "Runs rough, knocks". Shows oil pressure switch opening...
Forum:
04-08-2023, 07:01 AM
489
219,996
Posted By
RZNT4R
You can be whatever you want to be and live the...
You can be whatever you want to be and live the life you want to live, but cars are cold, unfeeling and uncaring machines and they will not wait for you.
But blowing through the service interval...
Forum:
04-04-2023, 06:35 PM
489
219,996
Posted By
RZNT4R
You see, I once came home, parked my car and...
You see, I once came home, parked my car and across the streets I could see two girls peering into the engine bay of an old hyundai accent. They looked puzzled, so I went to see if I could help.
Forum:
04-04-2023, 04:47 AM
489
219,996
Posted By
RZNT4R
Nope, you get no warning. There is an oil...
Nope, you get no warning. There is an oil pressure warning light, but usually when that comes on it's to inform you that shit is already bad. The recall is very far behind you and people who blow up...
Forum:
03-31-2023, 04:34 PM
17
recall done and the dealer broke my car
2,397
Posted By
RZNT4R
Or why not just set it on fire and watch it burn?...
OP, take care of the DTCs first.
Notice I don't say "replace the MAF". Take care of the DTC, diagnose the damn thing. If this it was going to...
Forum:
03-18-2023, 09:25 AM
6
Issues with studs / bolts
1,539
Posted By
RZNT4R
It seems like the twins are well know for having...
It seems like the twins are well know for having their studs chewed up, but I put the blame for that on people used to 1.5 thread toyota studs dealing with 1.25 thread subaru studs, which do not...
Page 1 of 13
1
2
3
4
5
11
Last
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine, Exhaust, Transmission
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
03:51 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
