Old 07-06-2023, 11:19 PM   #1
swiftskii
New clutch creaking noise
I just got a new clutch installed. Exedy clutch kit with new TOB. I also got verus fork and pivot installed. After a couple days, clutch starts making this noise when pressing it down slowly all the way. The noise is quieter in the cabin and louder near the slave cylinder area by the engine. I’m thinking I need to lubricate the pivot joint with grease. Any ideas? Thanks.
https://www.youtube.com/shorts/hQnkycC_6fQ
swiftskii is offline   Reply With Quote
Old 07-07-2023, 01:40 AM   #2
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
DIY or shop install?
Originally Posted by humfrz
I'm old and lazy
Old 07-07-2023, 04:37 AM   #3
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
My stock clutch fork does that, I need to get around to it.
Put a dab of EP grease on the end of the slave rod, if that doesn't fix it, transmission needs to get pulled off and grease applied to the pivot ball.
Old 07-07-2023, 01:16 PM   #4
swiftskii
A shop installed it. There was grease included in the clutch kit but I’m not sure if they installed it in the proper places
Old 07-07-2023, 02:10 PM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Which shop? What did they say if/when you asked about this?
I'm old and lazy
Old 07-07-2023, 02:28 PM   #6
RZNT4R
The extra small packet of grease included with the clutch is intended for the input shaft splines
Old 07-07-2023, 09:07 PM   #7
swiftskii
I applied Lucas Oil Products Red N Tacky Grease to the top of the pivot ball and the slave cylinder linkage. So far it's quieter but the noise is still there. There is no audible noise when the engine is on and It shifts fine so I am assuming its not a big problem to worry about... I will reapply again in a couple of days and keep observing for any changes
Old 07-07-2023, 09:09 PM   #8
swiftskii
Some local independent shop near my area. Since I brought my own parts they won't honor shop warranty. If my problem persists I'll give them a call out of curiosity.
Last edited by swiftskii; 07-07-2023 at 09:10 PM. Reason: Forgot to quote a response
Popping, Crunching and Creaking Noise MyEvilMonkeys Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-22-2020 12:50 PM
Creaking noise while turning WRITEX Issues | Warranty | Recalls / TSB 20 01-26-2020 05:25 PM
Creaking noise coming from the rear alex87f Issues | Warranty | Recalls / TSB 9 10-08-2018 11:47 AM
Creaking noise from overpipe sydious Engine, Exhaust, Transmission 4 06-27-2018 02:13 AM
Clutch creaking noise (not the clutch fork one...) treminaor Issues | Warranty | Recalls / TSB 59 10-23-2017 01:53 AM
