Drives: White Subaru brz
Hey guys I need help with a code
My 15 BRZ has code P2109. I can’t figure out why. I tried a test throttle body and a test PCM. The code won’t clear with my OFT and the battery disconnected. It popped up after I had reinstalled the intake manifold. I’ve checked no wires are pinched. Thanks
#2 | |
Maybe it will reset - ![]() https://studentlesson.com/how-to-res...sition-sensor/ |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Instead of trying parts, try a scan tool to read live data. You need to know the throttle plate position.
One of the following conditions is met (1 trip detection logic): The throttle position sensor opening angle when learning the fully-closed position is less than -4.02% or more than 4.02%. When the throttle actuator current is off, the difference between the actual throttle position and the fully-closed position is less than 0.93%. |
Drives: 2023 Toyota GR 86 Cup
Factory diagnostic steps below, is P2109 the only code set?
2023 GR Cup Car
And you said you've tried a known good throttle body against the one currently in the car? If so, It's got to be damage on the engine harness somewhere.
2023 GR Cup Car
Can’t 100% confirm if it is good considering i bought it used. I hate to spend the money on a brand new one considering I bought a grams throttle body for this thing not too long ago. But I won’t know for sure until I buy a new one 😕
Have you looked at the pins on the throttle body harness connector, make sure none are bent or missing?
2023 GR Cup Car
| DIY - Color Code of ID plate and code of part (SUBARU) - SB18-091 | Trap63 | DIY (Do-It-Yourself) Guides | 0 | 06-14-2018 04:52 AM |
| p0462 fuel level sensor code. anyone else ran into this code | georgiafrsguy | Engine, Exhaust, Transmission | 1 | 02-28-2017 08:28 PM |
| Lean Code and 02 Code diagnostics. | Kiske | Engine, Exhaust, Transmission | 12 | 04-28-2016 10:19 PM |
| CEL code | ChandlerSwyng | Issues | Warranty | Recalls / TSB | 2 | 04-08-2014 01:27 AM |
| BC Coilover settings you guys guys ride on | g0lden | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 04-06-2014 06:56 PM |
