Old 04-30-2023, 09:00 PM   #1
Dububster
Dububster's Avatar
Clutch Replacment?
I figured I would ask before I spent the money to get the clutch replaced because I am not 100% sure it is the clutch. After long drives, my clutch slips quite a bit in first gear when taking off, and the car shakes a ton. But it never slips when the clutch is cold or just being driven around town. Does the clutch simply just need to be replaced, or is it possibly something else?
Dububster is offline   Reply With Quote
Old 04-30-2023, 09:39 PM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Mileage? What RPM level do you take-off at? Does the clutch slip in 5th at WOT from 3k RPM-ish?
EndlessAzure is offline   Reply With Quote
Old 04-30-2023, 09:51 PM   #3
Dububster
Dububster's Avatar
The clutch only has about 18k miles on it, which is why I am not so certain it's that, but my brother/dad have driven it at times and REALLY roasted the clutch because of how weird the clutch is on our cars and how not used to it they were. 69k miles on the car. No, it doesn't slip in 5th at WOT from 3k miles. I take off at a low RPM, maybe 1.8k rpm? I always take off at the same rpm, and it's never high.
Old 04-30-2023, 10:00 PM   #4
EndlessAzure
Wheels for Brains
Seems like normal use cases. Maybe uneven deposits from being driven overly-hard/improperly?
Stock or aftermarket clutch?
The stock full organic clutch disc is pretty resilient.
Old 04-30-2023, 10:09 PM   #5
Dububster
Dububster's Avatar
Okay, it's a stock clutch. I also wanted to add that what I mean by slipping in first gear is if I don't rev it significantly higher than normal when moving from a stop, the car will shake a ton like it's about to stall; the lights have flickered too at times during this too. But again, this only happens after long trips or the clutch has been heated up by bad driving.
Old 04-30-2023, 11:06 PM   #6
EndlessAzure
Wheels for Brains
Yeah I'm not too sure. Maybe someone else will chime in with more insight.
I've had "chugging" when RPMs dip too low and the car is getting lugged, but that was on aftermarket clutch kit.
1800 RPM held seems pretty reasonable; maybe try raising take-off RPM a little bit to 2000 and see if it persists
The Following User Says Thank You to EndlessAzure For This Useful Post:
Dububster (05-01-2023)
Old 05-01-2023, 09:23 PM   #7
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
So you say it's slipping, but you describe the exact opposite.
What do you mean by "If I don't rev it significantly higher than normal" ? What's significant" what's normal? If I had to put words to what you're describing, it sounds like choppy engagement at idle?
There could be a number of reasons for that, some related to the clutch and some not. The throttle could be caked up and the computer has trouble compensating for the load at idle, the clutch may not be worn but you could have overheated spots on the flywheel or pressure plate, engagement could feel harsh if the throwout bearing is binding on the colar, likewise if the clutch disc is contaminated.
It's really hard to get a feel for a clutch via text.
The Following User Says Thank You to RZNT4R For This Useful Post:
Ohio Enthusiast (05-02-2023)
Old 05-01-2023, 10:16 PM   #8
Dububster
Dububster's Avatar
I see, I'll probably just take it into a shop. Normal is what I said above, taking off at around 1800 rpm, but when I am experiencing this issue I have to take off a lot higher maybe around 2500 rpm to not almost stall. What confuses me the most is that it doesn't happen on drives shorter than maybe 25 miles, I've narrowed it down to what I think is the clutch because if I deliberately heat up the clutch by driving it like I am new to manual (taking off at maybe 3000 rpm and getting it to smell)the symptoms will happen immediately after that.
Old 05-02-2023, 05:50 AM   #9
RZNT4R
If your normal is taking off at 1800, damn, maybe you do have some hot spots because "normal" should be barely above idle...
These cars are actually pretty hard to stall and gladly hook up at idle with no throttle at all.
soundman98 (05-02-2023)
Old 05-02-2023, 12:23 PM   #10
chipmunk
Drives: _
You describe something similar to what happened to me when I had old oil. If I recall correctly, it threw an error code for the VVT, perhaps lack of enough pressure.
Does it feel like the vibrations/shudders come from the footwell or somewhere else?
chipmunk is offline   Reply With Quote
Old 05-02-2023, 01:30 PM   #11
Dububster
Dububster's Avatar
You’re right that was an overestimate, I’m by no means launching my car and am taking off a little higher than ideal, but maybe there are hot spots from previous mistakes?
It’s interesting you say that because I’ve and everyone else who has driven my car think that it is extremely easy to stall, when I first bought the car and when I had the clutch replaced the first time. Even after driving my car for the past 4 years I’ve found it SIGNIFICANTLY easier to stall than say a wrx, evo, 370z, civic. If I try to get going without using throttle I have to release the clutch very very slow to not stall.
Old 05-02-2023, 01:34 PM   #12
Dububster
Dububster's Avatar
In regards to oil i don’t think it can be, if you are talking about engine oil I replaced it 2800 miles ago and had a oil analysis done and it was perfect. I want to say the vibrations come from the transmission because my shifter will shake violently but it’s hard to pinpoint because the whole car kinda shakes. There’s a lot a sort of chatter sound which sounds like it’s coming from the trans.
Old 05-02-2023, 01:41 PM   #13
Tokay444
You sure it's not tires slipping?
The Following User Says Thank You to Tokay444 For This Useful Post:
whataboutbob (05-26-2023)
Old 05-02-2023, 02:20 PM   #14
Dububster
Dububster's Avatar
Haha, yes 100% sure
The Following User Says Thank You to Dububster For This Useful Post:
Engine sound generator replacment..... plug and play Master Jedi GR86 General Topics (2nd Gen 2022+ Toyota 86) 11 04-02-2022 01:04 PM
Vibration after Clutch Replacment AT-JeffT Engine, Exhaust, Transmission 12 03-10-2020 08:09 PM
Windshield replacment vendor referrals jeepmor Northwest 2 07-09-2014 07:03 AM
BRZ Premium Reflector Replacment Jimmylightning Cosmetic Modification (Interior/Exterior/Lighting) 1 11-20-2013 11:35 PM
6x9's Stealth install - rear speaker replacment GTS86 Electronics | Audio | NAV | Infotainment 7 10-16-2013 09:55 AM
