follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Find All Thanked Posts
Go to Page...
Page 1 of 3
1
2
3
Showing results 1 to 30 of 62
Search took
0.34
seconds.
Search:
Posts Made By:
blakkoutdarko
Forum:
Scion FR-S / Toyota 86 GT86 General Forum
12-05-2022, 07:59 PM
25
Is my 86 healthy??
3,391
Posted By
NoHaveMSG
Depending on injection mode it could go to 0 on...
Depending on injection mode it could go to 0 on stft I believe. That's why you usually log injection mode too.
IAM at 0 is weird. I almost think there is an issue with the OFT reading correctly....
Forum:
12-05-2022, 06:18 PM
25
Is my 86 healthy??
3,391
Posted By
Spuds
Uhh... Advance multiplier is 0. That seems bad. ...
Uhh... Advance multiplier is 0. That seems bad. You normally want that at 1. (Edit, unless the tune has IAM set to 0, but that seems odd for an OFT tune)
OP, take a log and post it to datazap...
Forum:
12-05-2022, 03:45 PM
25
Is my 86 healthy??
3,391
Posted By
I see a smoothly idling engine. ;)
Forum:
12-05-2022, 03:31 PM
25
Is my 86 healthy??
3,391
Posted By
OP, Teseo's just yanking your chain. ;) ...
While driving, glance at your long-term fuel trim and knock correction for the most important indicators. LTFT should be within +/- 5% -ish. Shouldn't...
Forum:
07-27-2022, 03:39 PM
7
Installed a new steering rack, steering wheel isn't centered anymore
1,524
Posted By
Excellent! Happy trails!
Forum:
07-26-2022, 07:09 PM
7
1,524
Posted By
fify ;) OP, we've all had our first time...
fify ;)
OP, we've all had our first time doing this. It would be an actual miracle if it lined up after assembly. Just get it close enough to safely drive to the shop.
...carefully
Forum:
07-13-2022, 06:44 AM
3
How to install OEM steering rack?
985
Posted By
The full instructions for the rack will be in the...
The full instructions for the rack will be in the service manual.
Forum:
07-12-2022, 08:33 PM
3
985
Posted By
https://gt86stuff.onrender.com/t3Portal/ ...
Courtesy of Ultramaroon
Forum:
06-18-2022, 07:39 PM
16
Hit a curb after swinging it, what parts to replace.
2,375
Posted By
Grady
On the hub I would take it off and feel it. If it...
On the hub I would take it off and feel it. If it is early damage you will have a better chance of feeling the damage over hearing it. It should be smooth as you rotate it if you feel any roughness I...
Forum:
06-18-2022, 02:21 PM
16
2,375
Posted By
I would pull the wheel to remove the possibility...
I would pull the wheel to remove the possibility that the noise he mentioned is indeed something rubbing. Isolating the hub will make it easier to hear if actually a bearing issue. Also give a chance...
Forum:
06-18-2022, 02:05 PM
16
2,375
Posted By
Personally, I'd just spin the wheel and listen. ...
Personally, I'd just spin the wheel and listen. If you hear anything at all, even the slightest sound, the hub assembly is toast. Can't stress enough that bearings MUST run dead silent.
Forum:
06-17-2022, 07:48 PM
16
2,375
Posted By
The race an bearing are inside the hub. Take the...
The race an bearing are inside the hub. Take the wheel off and spin just the hub. If the bearing is damaged you should know pretty quickly.
Forum:
06-17-2022, 07:38 PM
16
2,375
Posted By
RedReplicant
My point was that the stock stamped steel arms...
My point was that the stock stamped steel arms will bend in an impact, but generally preserve the subframe. Something like a SPL may very well transfer that impact force into the subframe and bend...
Forum:
06-17-2022, 08:29 AM
16
2,375
Posted By
Check the hub. The weird noise you hear could be...
Check the hub. The weird noise you hear could be bits of smashed bearing.
Forum:
06-16-2022, 04:12 PM
16
2,375
Posted By
dragoontwo
Subaru 20202CA002...
Subaru 20202CA002 (https://www.subarusource.com/oem-parts/subaru-arm-assembly-f-right-hand-20202ca002). $174.26 + shipping.
Toyota SU00310055...
Forum:
04-21-2022, 05:22 AM
7
Tips after installing JDL catless headers
1,363
Posted By
alex87f
Permatex copper works great as a gasket dressing...
Permatex copper works great as a gasket dressing if you want to make sure there are no leaks. I wouldn’t use any other product though.
Forum:
04-21-2022, 12:01 AM
7
1,363
Posted By
jflogerzi
Check Wally's link. It give you all the TQ specs.
Forum:
04-20-2022, 05:56 AM
7
1,363
Posted By
Wally86
And it takes surprisingly little torque for the...
And it takes surprisingly little torque for the header...
https://www.ft86club.com/forums/showpost.php?p=3348814&postcount=5
Forum:
04-19-2022, 08:58 PM
7
1,363
Posted By
FSFRS
I'd get a torque wrench. Over tightening can...
I'd get a torque wrench. Over tightening can pinch the gasket and cause leaks. Uneven tightening can cause leaks. Too little tightening can cause leaks.
Forum:
04-18-2022, 06:15 AM
7
1,363
Posted By
Wally86
I would think the best way to avoid an exhaust...
I would think the best way to avoid an exhaust leak would be to evenly tighten the nuts down using the same amount of force across them all. But I'm no mechanic. :D
Forum:
04-14-2022, 05:37 AM
13
Winjet Fog Light wiring help
1,310
Posted By
Wally86
Break out the multimeter and test to verify...
Break out the multimeter and test to verify you're getting 12v on your source wire.
I assume you're going to a relay so double verify the layout of the relay wires. They're easy to get mixed up.
Forum:
04-11-2022, 04:02 PM
13
1,310
Posted By
kevaughan
I've done this but then you realize that you...
I've done this but then you realize that you can't close the fuse box with the lid anymore. At least in my case. You'll need to modify the lid somehow.
Those of us who live in wet wintery climates...
Forum:
04-11-2022, 12:47 PM
13
1,310
Posted By
rbfr.s
^^^^ What they said
What they said
Forum:
04-11-2022, 12:35 PM
13
1,310
Posted By
Wally86
He means "Add-a-Fuse" ...
https://www.amazon.com/JABINCO-Circuit-Adapter-Blade-Holder/dp/B0827L4HH9/
Forum:
03-18-2022, 05:17 AM
7
PLS HELP!?! Rear left brake locking up after wheel stud replacement.
1,038
Posted By
EndlessAzure
Yes to clarify, if you drove the car with a...
Yes to clarify, if you drove the car with a smoking brake for an extended amount of time (hours, days), it will be bad.
A short trip around the block you should be fine.
Forum:
03-17-2022, 08:15 PM
7
1,038
Posted By
I think you missed the opening statement there...
I think you missed the opening statement there End!
No you do not need to worry about anything. That short a trip would do little if any damage. The mechanic would have inspected it and told you...
Forum:
03-17-2022, 08:05 PM
7
1,038
Posted By
EndlessAzure
Yes, you should be worried. If the...
If the brake is dragging enough to be smoking, it will generate a lot of heat which can warp components and wear down the parking brake pad.
Adjust the...
Forum:
01-25-2022, 11:26 AM
6
Quick question before I install these RCE SS1
1,111
Posted By
Racecomp Engineering
Hard to see in the pics but looks like the camber...
Hard to see in the pics but looks like the camber plate is just pivoted to 1 side (which it's designed to do).
We only include 1 adjustment knob...keep it in your glovebox. :)
Give us a call...
Forum:
01-25-2022, 11:05 AM
6
1,111
Posted By
Easy Racecomp Engineering
Forum:
01-25-2022, 10:46 AM
6
1,111
Posted By
BigTuna
Its bolted to the ball joint that sits below the...
Its bolted to the ball joint that sits below the top plate. If you move the top hat, it should rotate around the nut. It's part of the design. What is the brand/model you are comparing them to? Not...
Page 1 of 3
1
2
3
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) -- General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
BRZ First-Gen (2012+) -- General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Issues | Warranty | Recalls / TSB
Engine, Exhaust, Transmission
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
DIY (Do-It-Yourself) Guides
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Engine, Exhaust, Bolt-Ons
Forced Induction
Engine Swap
Wheels and Tires
Transmission and Driveline
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Exterior Parts - Lighting
Coating and Customization Services
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Exterior Parts (Aero, Lighting, Etc.)
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
03:12 AM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2024 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
