Old 04-11-2022, 01:07 AM   #1
blakkoutdarko
blakkoutdarko's Avatar
Drives: 2017 Toyota 86 (Raven)
Winjet Fog Light wiring help
I have a 17’ 86 and wanted to know what’s the safest way to connect the red wire to the 15A fuse? I’ve seen people on Youtube literally just wrap the red wire around the fuse then pop it back in but i’m not sure if that’s safe and will lead to problems in the future.
blakkoutdarko is offline   Reply With Quote
Old 04-11-2022, 03:41 AM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
Add-a-fuse. And crimps. Never wrap wires. I have pictures of house fires that started from wrapping wires
Wally86 (04-11-2022)
Old 04-11-2022, 06:10 AM   #3
blakkoutdarko
how would i add a fuse to that fuse box under the dash?
Old 04-11-2022, 12:35 PM   #4
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
He means "Add-a-Fuse"
https://www.amazon.com/JABINCO-Circu...dp/B0827L4HH9/
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following 3 Users Say Thank You to Wally86 For This Useful Post:
blakkoutdarko (04-12-2022), rbfr.s (04-11-2022), soundman98 (04-11-2022)
Old 04-11-2022, 12:47 PM   #5
rbfr.s
rbfr.s's Avatar
Drives: 2014 FR-S
What they said
Professional Car Breaker
rbfr.s is offline   Reply With Quote
The Following User Says Thank You to rbfr.s For This Useful Post:
Old 04-11-2022, 04:02 PM   #6
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
I've done this but then you realize that you can't close the fuse box with the lid anymore. At least in my case. You'll need to modify the lid somehow.
Those of us who live in wet wintery climates need to be careful of salty water/snow/ice/slush/etc splashing upwards from your foot.
kevaughan is offline   Reply With Quote
The Following User Says Thank You to kevaughan For This Useful Post:
Old 04-11-2022, 08:35 PM   #7
soundman98
soundman98's Avatar
i believe the 3d printing thread has some extended depth fuse box covers for the purpose
Old 04-12-2022, 03:13 AM   #8
blakkoutdarko
Where can i find the “3rd printing thread” sorry if that’s a noob question
Old 04-12-2022, 05:46 AM   #9
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
https://www.ft86club.com/forums/showthread.php?t=123151
The Following User Says Thank You to Wally86 For This Useful Post:
soundman98 (04-12-2022)
Old 04-12-2022, 05:32 PM   #10
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
I think this is the model you're looking for: https://www.thingiverse.com/thing:88529
wolffbite is offline   Reply With Quote
The Following 2 Users Say Thank You to wolffbite For This Useful Post:
kevaughan (04-16-2022), soundman98 (04-12-2022)
Old 04-13-2022, 05:05 AM   #11
blakkoutdarko
I got the add a fuse thing from Autozone, so is it as simple as remove the 15a fuse and insert it into the circuit fuse tap? Because in my research of this process it says i need to add another fuse to the other side of the circuit tap. Which fuse should that be? Can it be any other fuse that powers up to 12v (do the little numbers on top of the fuses that comes in the box mean anything?) On the back of the Littelfuse brand box it says “This device is not designed for use with accessories requiring more than 10 amps!” do i now need to get a box that comes with fuses that can power over 10amps or 12v or something?
Old 04-13-2022, 12:36 PM   #12
wolffbite
Just the tip
wolffbite's Avatar
So this style of add-a-fuse lets you reuse the original fuse (to protect the original part of the circuit) and add a new one to protect the accessory you are adding. Both slots will need a fuse in them.
AFAIK you can get these with varying amperage ratings. So if you are tapping into an existing 15A fuse, you need one rated for at least that. The accessory you are adding can be 15A or less. The amazon link above seems to accommodate 15A fuses.
I've only used these myself for 10A or less for adding a dashcam, so I haven't run into needing one for 15A.
Old 04-13-2022, 10:28 PM   #13
blakkoutdarko
Everything is hooked up correctly but the fogs won’t turn on
Old 04-14-2022, 05:37 AM   #14
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Break out the multimeter and test to verify you're getting 12v on your source wire.
I assume you're going to a relay so double verify the layout of the relay wires. They're easy to get mixed up.
blakkoutdarko (04-15-2022)
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 08:42 PM
wtb: (1) yellow winjet fog light finch1750 Want-To-Buy Requests 2 01-22-2017 02:18 AM
WTB: Used winjet frs fog light bezel justin6280 Want-To-Buy Requests 2 02-03-2016 02:37 PM
Winjet Head Light (L) LPC_FRS Exterior Parts (Aero, Lighting, Etc.) 0 03-26-2015 10:59 AM
winjet led wiring to factory led fog strip? J_kennington Cosmetic Modification (Interior/Exterior/Lighting) 1 12-02-2014 06:04 PM
